Old 07-08-2010, 05:11 AM   #1
nazier
black shark
nazier's Avatar
Drives: black toyota yaris t3 sprit
help needed with cluster
hi buddies
please help this is a pic of my cluster in the right hand side of the cluster under the clock i can see some stuff like
avg/milesmphl/100km
oCmpg
km/h
how do i get this to work
www.justbabynappies.co.za
Last edited by nazier; 07-08-2010 at 05:16 AM. Reason: forget to insert a word by title
nazier is offline   Reply With Quote
Old 07-08-2010, 09:51 AM   #2
v1ru5
Drives: '08 3door
I think you mean left hand side of the cluster ;)
In the manual, they say pressing the button/knob to the right of the clsuter is meant to swap between the displays of average fuel consumption, avg trip distance, etc. but i also could not get mine to work.
v1ru5 is offline   Reply With Quote
Old 07-08-2010, 10:19 AM   #3
bigdave87
Drives: Yaris SR 1.3L 2009
if i press the button/knob it switchs between avg speed / avg mpg / mpg / outside temp / miles left in the fuel tank
bigdave87 is offline   Reply With Quote
Old 07-08-2010, 10:44 AM   #4
v1ru5
Drives: '08 3door
maybe the feature is removed depending on the model of yaris
Old 07-09-2010, 03:57 AM   #5
v1ru5
Drives: '08 3door
Was messing around with it yesetrday, the button on the right changes the display from ODO, to Trip A and Trip B. and the left button changes the display below the clock to Temp, AVG fuel consumption, avg speed and avg distance on your current fuel level.
Old 07-09-2010, 04:42 AM   #6
Qmobile
that's right I went there
Qmobile's Avatar
Drives: '08 Blazin' Blue,'10 Dark Red
I want one of those!! lol
Mods: 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals.
suggestions always welcome
Qmobile is offline   Reply With Quote
Old 07-12-2010, 04:04 AM   #7
nazier
black shark
nazier's Avatar
hi buddy
thanks but all i got was how to make the speedo brighter or dim, when i press the left button all i can do is change the time, if u can find out how to activate it i will owe
Old 07-12-2010, 08:06 AM   #8
BluYrs
ヴィッツ ドライバー
BluYrs's Avatar
Drives: 2006 3d 1.0 Linea Sol
Originally Posted by nazier View Post
hi buddy
The display is the same as on models, which have the so-called "computer". Models which have this feature also have another button on the other side of the display (like you have below the clock, check this pic of my car). Pressing the far-side button alternates the display as bigdave87 said. Probably your car just doesn't have this feature.
The blue one
Old 07-12-2010, 08:20 AM   #9
nazier
black shark
nazier's Avatar
ok so how do i get it to work, what do i look for, some say its there but it not activated becoz the dealer makes money when u want it, the 2005 had it when they did the review on it, so i need to know if the is a plug thats just not plugged in, or do i fit fuse into the fuse box which will switch it on,
Old 07-12-2010, 08:22 AM   #10
bigdave87
Damn Switched Car On Sataday Now Got Analog Dials So i Can't check :( sry fella
Old 07-12-2010, 08:25 AM   #11
nazier
black shark
nazier's Avatar
WWWWHHHYYYY?????
thanks buddy , is it hard to look for plugs behind the dash and how do i get behind the dash
Old 07-12-2010, 10:24 AM   #12
I think he means the back of the cluster unit itself? If you swapped your cluster, that means you've had it out and you've already been back there once.
Old 07-13-2010, 05:24 AM   #13
bigdave87
just been messing with the buttons on the analog cluster and it to has this feature but on the other side
This aint my cluster just looks same
if i press the green button
the red display changes though the same things as i stated above but also adds
''eco time for that trip'' and ''time eco been used total''
guessing the wiring should be almost the same so i'll take cluster out tonight and have a look and take some pictures
Successful Gauge Cluster Swap kac Cosmetic Modifications (Exterior/Interior) 37 07-06-2010 08:05 PM
New Cluster Problem. A1phazu1u Cosmetic Modifications (Exterior/Interior) 3 06-29-2010 07:00 AM
HELP!! Guage cluster not working joeljcruz86 DIY / Maintenance / Service 6 05-14-2010 04:37 PM
OZ CLUSTER Lewis DIY / Maintenance / Service 226 11-15-2009 08:19 AM
FS: Gauge Cluster from '09 LB- $150 MGargano Items for Sale by private party 14 10-05-2009 12:59 PM
