Old 07-12-2010, 01:22 AM   #1
detroiter
detroiter's Avatar
What's the proper way to check our auto trans fluid?
I wonder what the best way to check our fluid level is on the Yaris? Best to check it while it's cold or warm or while it's running even? And what would be the best level for it to be at. Thanks
Old 07-12-2010, 03:17 AM   #2
nazier
black shark
nazier's Avatar
Drives: black toyota yaris t3 sprit
hi buddy
make sure the vehicle is level and its running, your oil dip stick should have hot and cold levels on it, if its not changing smooth the oil could be a little low, and if the oil is dark change it,
www.justbabynappies.co.za
nazier is offline   Reply With Quote
Old 07-12-2010, 05:13 PM   #3
GeneralDon7
Drives: Yaris Sedan
isnt he talking about the transmission fluid? Which if i remember right is to the right of the oil dipstick.
GeneralDon7 is offline   Reply With Quote
Old 07-12-2010, 11:07 PM   #4
Hershey
it's on the drivers side in the front of the engine . Take car for a good run of 10 miles or so to get the fluid hot . Then park it on a level surface with the engine running and work through all the gears ( reverse too ) several times . Get out with car running in PARK ( hand brake on if you want ) to read the level which should be at or near the HOT level mark .
Old 08-28-2010, 01:01 PM   #5
boodage
Drives: 2006 Yaris RS
What do the various markings mean on the auto transmission dipstick?
boodage is offline   Reply With Quote
Whats the best auto trans fluid and why? detroiter General Yaris / Vitz Discussion 11 07-02-2010 06:07 PM
Effects of too much trans fluid in the case? (auto trans) detroiter General Yaris / Vitz Discussion 5 02-24-2009 11:08 PM
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 10:57 PM
