Old 07-13-2010, 04:25 PM   #1
zbouncer
Drives: 2008 Yaris LB 5MT
Question STS Rear-mount Turbo
Did a couple of searches for a rear-mount turbo on a Yaris and so far it looks as if it has never been done before, nobody thought it was interesting or nobody thought of it
Here is the link http://www.ststurbo.com/universal_turbo_systems
Lets discuss some pros and cons
zbouncer is offline   Reply With Quote
Old 07-13-2010, 04:34 PM   #2
Looks like this application is for larger cars and trucks, looking at the website.
I think it's more piping (= more lag on our cars), custom set up (just as much or more work than a front mount), can't think of any pros except "cool factor".
Old 07-13-2010, 05:36 PM   #3
zbouncer
Yeah they get great results on LSX cars/trucks...just thought I would throw it out there...it didnt really say the size of pipping it comes with. I know this system is made to bolt up to stock f-body pipping (which cant be more than 2" from the factory), and the exhaust gases and intake air wouldn't have to travel as far on a Yaris LB as opposed to those other boats?
And yeah they sound freakn sweet back there ;)
Old 07-13-2010, 09:10 PM   #4
advocate
Drives: car
if you want to be unique you should buy the new microimage hood and do a top-mount intercooler
Old 07-14-2010, 10:48 AM   #5
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
+1
Its a Chao!!!
Old 07-15-2010, 11:45 PM   #6
XYaris
Drives: '09 Yaris LB
I have seen a rear-mount turbo on an integra before and Super Sport has a Lexus IS-F with dual rear turbos in it this month.
I think that its a cool idea that you see pop up every now and then (never seen the idea mentioned on YW before though). Do it.
XYaris is offline   Reply With Quote
Old 07-19-2010, 04:56 PM   #7
severous01
buddy in jersey had one on his camaro. it wasnt too bad, and lag wasnt any more noticeable than a normal turbo setup. it's a good idea, removing heat and space taking stuff from the engine bay and moving it to the back of the car...bmw and mercedes have been doing this for years with batteries, why not turbos? the piping acts as an intercooler (although not a good one) and you can use any size turbo/piping you want (depending on spacing available). the real problem i see is that it's on the rear of the car, unprotected from all the thieves out there. it's so far back, and just under the bumper...very easy access specially if you back into parking spots.
other than that, go for it. you wont need a muffler, and all you'd rally need is a metal intake plenum or manifold.
Old 07-24-2010, 08:56 PM   #8
Cosmonaut
The Last Baron
Cosmonaut's Avatar
Drives: 09 Polar White HB
lol. cool factor is about it. more tubing=more money. and im sure heat loss will degrade the maximum efficiency of the turbo...unless you will be using some kind of thermal barrier. plus the intake side would most likely become an interheater rather than an intercooler.
Sanction this outbreak, a Virus conspires. Single sparks are Spectral Fires!
| UR 19mm sway |
Cosmonaut is offline   Reply With Quote
Old 07-25-2010, 10:26 PM   #9
justjesus
justjesus's Avatar
Drives: 2008 Liftback
STS has been doing it for years....with great success. They did their homework and made it work. Surely they might be able to make some suggestions for a smaller displacement engine. Just call and ask ;)
Old 07-26-2010, 02:52 AM   #10
ok, pros and cons have been discussed.
zbouncer, you going to do it?
Old 07-26-2010, 10:21 AM   #11
severous01
if i had the money i'd do it....
money and a metal intake manifold!
Old 07-27-2010, 01:30 AM   #12
Pur_Blu
Pur_Blu's Avatar
Drives: NCVC craziest
Send a message via AIM to Pur_Blu Send a message via Yahoo to Pur_Blu
interesting... i've seen this company years ago. its geared more for american cars/drag cars but there are a few clips around youtube of some imports fitted with STS. It doesn't seem like it comes with any computer controlled ecu or piggyback unit nor did they offer bigger injectors and all the little things people tend to overlook with power adders. Im guessing they are banking on the customer knowing this and supplying parts themselves. Or using that electric boost controller and low boost to save the motor.
Pur_Blu is offline   Reply With Quote
Old 07-27-2010, 02:59 PM   #13
severous01
the universal kits dont come with anything but a turbo setup. which is good for someone who knows what they need and can get it...but bad for someone just wanting to throw it on n be done w it.
the specific kits come with injectors, programming options, setup options, turbo options, all sorts of options. even dual stage electronic wastegates. my friend's camaro has the dual stage w/g. he runs 13 on street and about 20 on the track with track gas.
Old 07-27-2010, 03:00 PM   #14
where's the OP
Old 07-27-2010, 04:02 PM   #15
hatchbackkid82
Drives: .
http://www.youtube.com/watch?v=BdY2_lmeTX0
Here you go rear mount turbo festiva
Old 07-27-2010, 05:07 PM   #16
^ why did you design a front mount turbo for your car?
Old 07-28-2010, 09:43 AM   #17
severous01
hey, any news on that metal intake manifold that was supposed to come out in december???
Old 07-28-2010, 12:36 PM   #18
Yeah -- it didn't. However, I did get the finalized drawings, so it's off to a new fabricator.
FS: 2005 Scion xA RS2.0 Turbo uberegg Cars for Sale by private party 40 04-03-2010 11:45 AM
HKS turbo timer type 1 Tamago Performance Modifications 3 07-21-2009 11:59 AM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
DIY Camera Mount -- No Cost Version KCALB SIRAY DIY / Maintenance / Service 20 06-08-2009 03:12 PM
