Old 07-17-2010, 12:18 PM   #1
yaris_trd
Drives: toyota yaris hb
Question i have a little problem
i have problem with the fan does not turn when the car is on and the engine temperature reaches its unique hot and the fan is turned on with the air conditioning on. guys i hope can help me thanks
yaris_trd is offline   Reply With Quote
Old 07-17-2010, 05:10 PM   #2
auxmike
auxmike's Avatar
Fan comes on at about 202F.
Without a Scanguage, you would never be able to tell if something's wrong with the fan circuit.
What did you use to determine there's a problem?
Old 07-18-2010, 12:00 AM   #3
yaris_trd
I added a water temperature clock and have seen q reaches 210 degrees and the fan does not run and that it happened from a few days
Old 07-18-2010, 03:03 AM   #4
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Check fan relay situated into the engine bay. It could be just as simple as a loose contact
Old 07-18-2010, 10:57 AM   #5
yaris_trd
pardon me for asking but where exactly is located the relay that saw many and not all is well which saw one that said no.2 and cooling fan which is not
Old 07-18-2010, 09:09 PM   #6
Fan No. 1 Relay is within the four relay block (the chunk with the EFI, HORN, and AM2 fuses on it) within the under hood fuse panel. Fan No. 2 is the one marked with the *9 below. Besides the relays, check the RDI fuse (the one marked *4 below).
Yaris Central Locking Problem pbasuita UK 0 07-10-2010 03:46 AM
interior lighting problem tied with headlights 40oz DIY / Maintenance / Service 7 03-28-2010 07:52 PM
Launching @ 4Krpm problem .... need tips Parmas Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 12-30-2009 08:11 PM
How can I get in touch with Toyota Regional Offices in Houston? woof DIY / Maintenance / Service 11 11-28-2009 09:29 PM
Service Problem Lizardboy DIY / Maintenance / Service 19 10-06-2006 09:12 PM
