Old 07-19-2010, 08:07 PM   #1
YarisSedan
Drives: 08 Yaris Sedan
Question about cutting the rear spring perches
A 350z came into my shop today with a strange request. Asked us to remove his rear spring perches and cut them in half. Only took a few minutes with a hacksaw. Dropped his car effectively 1 inch without having to cut his lowering springs. We cut the top part of the hat leaving the lower portion of the perch intact that keeps the spring centered.
Gave me the idea for the yaris if this is possible. Havent had a chance to look at our spring perches but i know they are kinda small. Has anyone attempted this. I think the top one you have atleast 1/4 of a inch you could remove. I think if there is a half a inch room in there to cut off the top this could effectively lower the rear to offset removing the spare tire to give you a even drop look without effecting your spring rate. I think its safer alternative than just removing the perch all entirely.
Old 07-19-2010, 08:19 PM   #2
Billiam
Drives: '10 White Yaris 4D LB
Something related to what you're talking about.....xA guys sometimes remove the upper rubber seat and wrap the top of the spring in thin tubing to prevent noise. That usually gives a 1/4 inch or better addtional drop. No cutting of anything is needed.
If you want to enjoy your car, stay off of the internet.
Old 07-19-2010, 09:26 PM   #3
YarisSedan
Its my understanding though the top rubber perch keeps the spring centered and prevents it from shifting around on the rebound.
Old 07-20-2010, 12:36 AM   #4
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
never cut springs.......
Old 07-20-2010, 08:19 AM   #5
firebob
Drives: 09 yaris
I don’t think were talking about cutting the springs but cutting the spring perches.
09, 3 door lift back, auto. I live on the road with my wife. We travel as needed for our work and drive up to 4,500 miles in a bad week.
firebob is offline   Reply With Quote
Old 07-20-2010, 09:10 AM   #6
severous01
you can take the rubber boot out and put water hose or coolant hose on the spring to stop noise. i did that on my camaro but it was a 3/4" spacer, not 1/4
Old 07-20-2010, 10:50 AM   #7
ddongbap
rEADING iS fUN dA mENTAL
Old 07-20-2010, 10:22 PM   #8
bzinn 1
bzinn 1's Avatar
my bad....lol
Rear spring swap info The Spectacle Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 02-22-2009 09:37 PM
ideal spring rates for coil-overs on Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 30 01-27-2009 04:24 PM
TANABE DF210 Spring Install [pics] Chris07LB DIY / Maintenance / Service 148 07-16-2007 09:26 PM
