Old 07-19-2010, 09:55 PM   #1
jcemitte
Drives: 09 yaris sedan
Performance Priorities....What goes first?
OK, So.
Time to get down to business. i was all set with a little chunk of change to dump on garm for some wicked awesome bolt-ons,
but family comes first and now thats all gone. so slowly, paycheck by paycheck, i will now have to buy things slowly.
The Rundown
My Car: 09 yaris sedan
My Goal: 200whp
My Actual Goal: Whatever i can get out of a sedan with a slush box.
(TOYOTA ARE YOU LISTENING!!! FOUR DOOR SUB-COMPACT PERFORMANCE CARS ARE COOL, SO GIVE US A FACTORY FIVE SPEED ALREADY!!!!)
The Plan
Starting at the front I suppose
1.) DC headers
2.) NST pulleys (do underdrive pulleys make your a/c not work as well?)
3.) Undecided on an Intake, suggestions?
4.) Nitto mid pipe, does anyone have a link to buy this thing?
5.) DC axle back
6.) Tien springs
7.) Tokico blues
after its payed off i am going to turbo the shit outta this thing, but thats a ways off. in the mean time i will just read about how awesome a ball bearing turbo would make my life
what order should i buy stuff? i cant decide.
I have a few questions as well.
Is a Grounding kit useful or worth anything to a non swapped motor?
Is there a performance intake mani availible for us? (cough cough garm)
Is there something ive missed
well at any rate ill buy as much as i can from micro image and see what kind of madness i can get out of my slushy sedan.
jcemitte is offline   Reply With Quote
Old 07-20-2010, 01:04 AM   #2
mario98c
mario98c's Avatar
You want 200whp?!?! Get a Turbo!
Old 07-20-2010, 09:16 AM   #3
severous01
you'll never get 200 hp out of this thing without spending tons of cash in finding someone to reprogram the ECM or finding a standalone fuel management system.
second, you'll never reach 200hp without some sort of power adder...easiest but most unreliable (longevity terms, not power terms) is nos, and it's also the easiest and cheapest to install and upkeep. you can get a 100hp kit from anywhere for less than 600 bux, fill the tank for 30 and even pay someone 200 or so to install it....so for less than a grand you got 200 hp total. but, i wouldnt go more than about a 35 shot if i were gonna keep it as any sort of driver.
you can turbo, there are kits for about a grand out there...or you can pay more for better gear (i'd definitely suggest paying more than a thousand for a turbo setup...you get what you pay for)
but, for you to dream that you'll hit 200hp naturally aspirated on the stock engine is just...sensless. now, put a celica engine in there...sure...drop a honda engine in there...sure. but, the stock 1.5l engine will likely never see 200 hp without some sort of power adder. there are no cams available, no tuning software, no heads, and people have even used different combos of pistons/cranks and still not reached 200 hp. someone here has a blitz supercharger and he's only at 135hp. and there's a turbo car somewhere around the 175 range.
but to answer your question, if you want to start somewhere, start on suspension. because no matter what you do to engine/turbo/sc/nos, whatever....you'll always use the suspension. and unless you change engines, you'll always use the same suspension design or similar. so...i'd go springs/swaybar/shox n struts.
if you do turbo you're wasting your money on axleback and headers and midpipe. and if you supercharge, well...you need all that stuff, but you may need bigger than whats available...so wait till you 'need it' to get it.
pullies are always good,
intake...again, if you go turbo you wont need it, and the supercharger comes with it so .... whatcha gonna do there???
and again, check the for sale section, there's always goodies in there for ya. i got my AFE intake for 50 bux, HID's for 50 bux, and a pulley set (almost) for about 50 bux.
Old 07-20-2010, 09:32 AM   #4
1. intake
2. lowering springs
3. rims + tires
Old 07-20-2010, 09:39 AM   #5
Vioz
Drives: 2008 Yaris Sedan
Send a message via AIM to Vioz
Unless your garm pushing 300+ hp all built up engine turbo wat/met inject etc etc lol otherwise with just those addon's you posted you would probably get about 5-8 hp gain no more.
If you want to do 200+ whp
go online and search car-parts.com or go to a junk yard and buy the same engine to build in your garage, engine shouldn't be more than 800$, i found some nearby me for 400$ even with only 10k miles on them and so on.
heres some information on what garm did on his built engine http://www.microimageonline.com/foru...-turbo-project
I tried searching but I remember finding a post with a link to a website with instructions on the build.
Basically you need to shell out close to $10,000 depending, if you do it all yourself it will be less.
a.k.a. "Aothachos"
Vioz is offline   Reply With Quote
Old 07-20-2010, 10:04 AM   #6
I got 17 whp from the bolt-ons and have the dyno to prove it. It's a respectable gain and you can feel it.
There should be a turbo kit available soon that pushes about 150 whp.
200 will require a turbo and a tune on the dyno, and a stock motor probably wouldn't handle it for a long time.
An N/A 200 whp would be a really fun project, but a LOT of work.
let's see how the Gude cams do on H3llion's car, there may be some hope for more substantial bolt on mods yet.
Old 07-20-2010, 11:51 AM   #7
jcemitte
I suppose 200whp is extremely ambitious...
thanks for bringing me back down to reality lol
I've talked it over with the wife and i could just get a rsx and boom presto
200hp
but i really like my yaris and i dont want to abandon it just because he is a little under powered, and i feel like a motor swap is losing its character... unless maybe to a 2nz or what ever the carolla motor is with the vvti...
so i suppose figure out a carolla motor build, or be happy with what i have, because as it is, its already a fun nimble little car. i mobbed down to long beach for spocom driving very irresponsibly and still had a blast and got 36mpg.
maybe thats the whole point of a sub compact....i just had an epifany!
im just going to stick with whats availible for the stock motor bolt some shit on and appreciate the car for what it is.
Old 07-20-2010, 02:17 PM   #8
^ that sounds like plenty of fun.
Don't forget, as other have mentioned, that some handling mods make the car even more fun.
Old 07-20-2010, 02:51 PM   #9
kou
Drives: 08 lb
200HP NA has been done by G-force garage in japan.13:1 compression,cams,
ITB's and a new gear set for the trans.
Old 07-20-2010, 03:46 PM   #10
Focus_Sh1ft
Focus_Sh1ft's Avatar
This is exactly how I feel. Personally, I get so much satisfaction in modding a car that so few people have even seen as more than just a fuel economy box. Anyone can go out and drop a few 10ks on a nice car, but modding an already unique car is just cool.
The potential for performance (and especially handling) is there, you just need to realize it.
It's pretty funny that no one I know takes a Yaris seriously. The other day I took one of my nay-saying buddies out for a spin and as soon as he saw how flawlessly the car was taking turns at 70+ mph he shut up pretty quick.
Old 07-20-2010, 04:15 PM   #11
That's why you have us.
.... and the guy you took out for a spin.
Old 07-20-2010, 05:23 PM   #12
jcemitte
OMG my wife is killing me!!!!
i just called her and asked (i have a vaction coming up this weekend mind you) if i could spend $480.00 on some springs and shocks/struts
she said no
then i asked if i could spend $280.00 on aformentioned shocks/struts
she said no
then i asked if i could at least buy the springs
you guessed it...no
then i reminded her that i spent $280.00 so we could leave a night early and stay in the room for a total of four hours and told she owes me at least a cold air intake
she said no
im dying to buy something and im not good at patience.
Old 07-20-2010, 07:45 PM   #13
1NZYaris1
1NZYaris1's Avatar
she said no
she said no
you guessed it...no
she said no
Or Negotiations eathier, reading the above
Old 07-20-2010, 07:54 PM   #14
Sooooo Whipped!!!! LOL Whip it!!
Old 07-20-2010, 09:11 PM   #15
jcemitte
god i know remind me to look for my balls in her purse when she gets home sheesh
i might just order it anyways
you know get my man hood back
not likely
Old 07-20-2010, 10:31 PM   #16
sleey0
Drives: 2008 Yaris LB
I am starting with the simpler stuff first.
Just ordered the TRD exhaust. Then I'll get the TRD CAI when I have some money to burn.
After that, prob DC headers.
sleey0 is offline   Reply With Quote
Old 07-21-2010, 03:54 AM   #17
LOL @ the wifey story. I got no advice for you, mine is cool that I am pursuing my passion, as long as the bills are paid.
Old 07-21-2010, 03:45 PM   #18
severous01
so...are those cams available yet? i'm not doing anything until they are. i'll do it all at once n be done with it.
also, how's the programming/timing issue going to be solved with a cam swap?
The Yaris Performance Primer eTiMaGo Performance Modifications 31 10-20-2025 09:08 AM
December at TWM Performance! TWM Performance TWM Performance 17 01-08-2010 09:14 AM
>>>>>> Boxing Day Sale at TWM Performance; Short Shifters and Shift Knobs <<<<<< TWM Performance TWM Performance 0 12-24-2009 10:21 AM
Black Friday SALE from TWM Performance! TWM Performance TWM Performance 1 11-27-2009 11:46 AM
Yaris Performance Specs neohalo Performance Modifications 22 06-24-2007 08:46 PM
