Old 07-22-2010, 09:29 PM   #1
velofille
Drives: Toyota Vitz 1999
Adding Rear Speakers
I have a Toyota Vitz 1999 1000cc (same as the Echo/Yaris etc).
It comes with front speakers but no rear ones, and I have some nice 6x9 that should go nicely in the back.
Ive searched fairly hard but can't find best method for this. Does anyone know if speaker wires are already run to the back anywhere? if so where?
And if not, whats the best way to attach them to the stock standard stereo?
velofille is offline   Reply With Quote
Old 07-28-2010, 02:05 AM   #2
velofille
Turns out no wires, will have to run some :)
Old 08-26-2010, 02:42 PM   #3
deadalus
Drives: Yaris/Vitz 99
Hi there,
I'm trying to attach two rear speakers. please help me to find how to attach the wires to the exsisting setup...?
Please help.
Mohan
deadalus is offline   Reply With Quote
Old 08-26-2010, 06:24 PM   #4
swidd
Drives: Yaris HB
You can always cut into the existing wires, either at the base of the front door frame (difficult), or behind the stereo (cut into the harness - easy). Just solder or cramp them together, you'll need to turn the knob up slightly higher to get the same volume... Also, don't use power hungry speakers if running off stock unit.
There are wire color list/diagrams in the stickies, and the harness is easy to access and cut in.
Is worth it to replace only front and rear speakers? tealio In Car Entertainment + Electronics (audio / video / alarm) 35 04-16-2010 09:11 PM
Fitting rear speakers in Toyota Yaris nish1979 In Car Entertainment + Electronics (audio / video / alarm) 4 03-22-2009 11:56 PM
Help needed! Fitting rear Yaris Speakers ovalbuster In Car Entertainment + Electronics (audio / video / alarm) 4 06-28-2007 12:29 AM
rear speakers not loud at all? davembfan General Yaris / Vitz Discussion 16 06-20-2007 02:29 AM
