Old 07-26-2010, 10:35 PM   #1
sleey0
Drives: 2008 Yaris LB
Made a really big boo-boo....
I am so pissed right now.
I accidentally rubbed off clearcoat off the back hatch. I was using a sponge that had goo gone on it still and didn't realize it until too late.
Do you guys think some clear coat polish or something like that would work?
Or do I need to call the body shop tomorrow
Any help would be great.
sleey0 is offline   Reply With Quote
Old 07-26-2010, 11:03 PM   #2
UTVitz
UTVitz's Avatar
Drives: Black Vitz Liftback
If it were me I'd go get a professional opinion (a body shop you like or know of)first before doing anything else. Tell them what happended and they should be able to figure out if you really removed clear coat or if you just made it hazzy. They should be able to offer some advise-that's what I'd do.
Old 07-27-2010, 12:01 AM   #3
big lo
big lo's Avatar
Drives: 2007 VIOS
Did you try waxing the area, to bring back the shine?
Old 07-27-2010, 12:09 AM   #4
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
Get some dish soap,why you ask,to clean out any residual googone from the area,then get some polish and a buffer and give it a buff,if that amkes the shine come back then add more polish then some wax.....I regularly use rubbing compound on my cars and can always polish back any hazing in a matter of minutes,the clearcoat should of held up fine to googone,I use it to remove tree pitch at times.
Old 07-27-2010, 02:34 PM   #5
bobolinko
Bob
bobolinko's Avatar
Drives: Yaris and Scion XD 5 spd BSP
The Goo Gone ppl say their product is CLEARCOAT SAFE...
Maybe all you have is some of the muck that the goo gone took off and looks bad. You could try buffng/waxing the area and maybe all is good..
Good luck !
bobolinko is offline   Reply With Quote
Old 07-27-2010, 05:39 PM   #6
sleey0
Thanks for the replies guys. I got some ultimate compound and nxt.and it looks somewhat better.
Let this be a warning to all - goo gone does in fact remove clear coat.
I guess i will find some better polish than meguiers. Any recommendations?
Thanks!
Old 07-27-2010, 05:40 PM   #7
sleey0
Thanks!
Old 07-28-2010, 08:30 AM   #8
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
Are you sure it was the goo gone, or was it the fact that you were using a sponge that had an abrasive surface (or had trapped grit in the surface)?
I've used Goo Gone a number of times and have never seen it removed clear coat.
Old 07-28-2010, 11:33 AM   #9
sleey0
I don't think a regular kitchen sponge (the kind with the soft and rough sides) would do that by itself.
It had to be the combination of the goo-gone and the rubbing.
Old 07-28-2010, 04:48 PM   #10
YarisSedan
Drives: 08 Yaris Sedan
Goo gone wont damage cured automotive clearcoat. What happens is it strips off all the wax completely off the surface. Also the rubbing might scratch and haze the clearcoat depending on what type of rag you use. Typically rubbing compound afterwards and wax will correct the issue. If you went below the clear coat for example your car is red you will see red staining on your rag. If not the clear coat is still intact.
Old 07-28-2010, 06:36 PM   #11
sleey0
The sponge wad slightly black afterwards.
Trust me. I have done many coats of rubbing compound and wax and it still doesnt look right.
Def took the clearcoat off.
Old 07-28-2010, 10:33 PM   #12
YarisSedan
Yeah if it was slightly black afterwards then you defiantly took clear coat off. If you dont clean and wax it frequently now eventually now that the clear is gone and thin in surrounding areas when it starts to rain water will get in under and the clear will start to lift and bubble. Then it will start to peel. The best way now is to get a can of clear coat and just spot treat the area. Wet sand and polish the area till its blended in.
If you dont feel comfortable doing something like that i would try craigslist for a mobile paint doctor.
Old 07-28-2010, 11:33 PM   #13
sleey0
I think I might just be real careful with the spot for now. If I notice anything I will take it to the body shop.
reworking the small lb area shouldn't cost too much.
Stupidity is expensive...
Old 07-31-2010, 10:24 PM   #14
Yarisduder
Yarisduder's Avatar
Drives: 2007 4dr Sedan Silver Streak
The rough side of a kitchen sponge is quite abrasive, generally as abrasive as 000 steel wool. Even more abrasive if it has been impregnated, such as an S.O.S. pad.
Yarisduder is offline   Reply With Quote
Old 07-31-2010, 11:59 PM   #15
sleey0
It said scratchless on the package fwiw.
hahaha
Old 08-01-2010, 09:53 AM   #16
Yarisduder
Yarisduder's Avatar
Maybe you can get the sponge company to pay to fix the clear coat, if it said scratchless, just leave out the part about the Googone... or maybe each company can pay half?
I bet you can write a letter saying you were dissatisfied and they send you coupons to buy more of their same product.
Supercharged Yaris: Greatest Yaris video ever made. TRUST ME! PETERPOOP Photo-Video-Media Gallery 54 08-29-2013 03:27 PM
07 yaris home made intake not working John_v63400 Performance Modifications 13 10-09-2012 12:55 AM
A Big Thank You To Everyone And *MAD DOG*'S Holiday Picture Thread. *MAD DOG* California 19 02-01-2009 08:56 AM
Made in...? Sabina74 General Yaris / Vitz Discussion 9 04-11-2007 10:44 PM
MacNeil Automotive products misrepresentations tomjasz Cosmetic Modifications (Exterior/Interior) 44 11-05-2006 04:06 PM
