Old 07-29-2010, 12:20 PM   #1
chrsfrm
Drives: Yaris 1.4 T Spirit
Loose wire by fuel filler tube/neck.
Hi Guys, just had a tyre changed and whilst up on jack I noticed an unconnected wire. It is a single black wire, not in a pair, with a small female connector crimped on, not a blade one but round, approx 1mm diameter. Nothing obvious for it to connect to, no empty spade. Sits in a crease down the back of the filler neck. I wonder if it is a static earth? My car is a diesel so I don't have a Haynes or other manual to help. Can anyone help with this please. Thanks guys.
chrsfrm is offline   Reply With Quote
Old 07-29-2010, 01:11 PM   #2
I just looked through all of the documentation that I have on the diesel and couldn't find anything showing a wire by the filler neck. Our gasoline ones don't have any wiring there.
Is yours a 1st or 2nd generation Yaris?
Old 07-29-2010, 01:37 PM   #3
chrsfrm
Hi CT, Thanx for trying.
It is 1st I gues, being a 1.4D 2004 year T Spirit.
Regards
Chris
Old 07-29-2010, 02:26 PM   #4
severous01
antenna for TPMS???
Old 07-29-2010, 03:20 PM   #5
Originally Posted by severous01 View Post
antenna for TPMS???
04 didn't have TPMS.
If it's a 5 door, it could possibly be the wire going to the door courtesy switch for the rear door, as that is a small single conductor wire. In that case though, the dome light would stay on, and the door open indicator would be on on the cluster.
Old 07-29-2010, 04:05 PM   #6
chrsfrm
Thanx both.
AS CT syas mine does not have TPMS.
Won't be a rear dooe courtesy either as its length is only that of half way down the filler neck, stops where the tank joins tube by bolted bracket. No warning lights are on either. All very odd. Doesn't look like any aftermarket addition.
Old 07-29-2010, 04:11 PM   #7
Can you post a picture? That might help in tracking down what it is.
Old 07-30-2010, 04:33 AM   #8
chrsfrm
Here are 2 pics. You can see the size of wire against my finger size. Thanks.
Old 07-30-2010, 10:54 AM   #9
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Could you back up a bit and take a photo of it from a distance - where the wire is entering the fuel filler area? It's not the wire to open the filler door from inside the car is it?
Old 07-30-2010, 11:03 AM   #10
I was wondering that as well. The way that the end is fused onto it makes it look more like a mechanical cable than an electrical one.
Old 07-30-2010, 12:01 PM   #11
chrsfrm
Thanx guys, the filler cover still opens & closes easily as usual so I do not think it is that. It was my first thought too.
Old 07-30-2010, 12:09 PM   #12
chrsfrm
Tried some more pics but to be honest they did not show up anything more than the others. It is a bit tight in teh filler area. When you see the wire in real life it still looks like a single electrical wire with a female connection. The only possible places it could connect would be on bare metal, on the tube clamp. Is there a static earth to the filler? Not sure why though as filler tube is plastic.
Old 07-30-2010, 12:58 PM   #13
I'm stumped, as there's no ground shown in the EWDs anyplace near there.
I just looked at the EPC to see if it showed a harness that for some reason the EWDs lack, but it didn't. Here's the 04 diesel's fuel fill as shown by the EPC:
Old 07-30-2010, 01:05 PM   #14
chrsfrm
Yes, I had seen that diagram, no sign of the wire. I may just have a rogue wire sitting there. I'll put a voltmeter on it see if it shows anything, or also for continuity. Thanks for taking the time to help. Regards, Chris.
Old 02-10-2011, 10:02 AM   #15
Madman1375
Drives: Yaris 5 dr 2007
Fuel filler door won't open inside lever won't pull up either any ideas?
Madman1375 is offline   Reply With Quote
Old 02-10-2011, 11:24 AM   #16
Vinceb
Drives: 2008 5 Speed Sedan
is it frozen? (in Nova Scotia, that can easily happen in winter)
if there is no tension whatsoever on the release, then it could be a broken cable, if there is tension, then it's probably just stuck.
Have somebody pull up on the release (or prop it up so it's fully extended) and then using a small flat head screwdriver try to pry the door open.
*** make sure you wrap the long part of the screwdriver in cloth or something soft so you don't destroy your paint and cover the end of it as well. don't pry too hard either***
hopefully it opens and you can either clean it, or replace it - be warned though it may not close again after opening it if it's a mechanical issue.
Vinceb is offline   Reply With Quote
Fuel Efficiency and the Yaris BailOut Fuel Economy Forum 327 01-02-2026 11:44 PM
Blitz S/C being installed this Saturday! LtNoogie Forced Induction Forum 179 12-14-2012 08:53 PM
Last Fuel Bar andaconda Fuel Economy Forum 37 04-29-2009 02:35 PM
