Old 07-31-2010, 07:47 PM   #1
trx73
Drives: 2006 Toyota Yaris Silver Hatch
tire choice????
I have 16x7 rims with 38 offset, I am torn on which tires to go with. I am not lowering the car so I want the wheel wells to look fuller with out any rubbing. 205 45 16 or 195 50 16??? any help would be appreciated
trx73 is offline   Reply With Quote
Old 07-31-2010, 08:35 PM   #2
205/50/16
Old 07-31-2010, 09:10 PM   #3
trx73
you think 205 50 16 won't rub??
Old 07-31-2010, 09:42 PM   #4
kimona
kimona's Avatar
Drives: 2014 White VITZ
205/50/16's won't rub, but with ET38, I'd go with 195/50/16's.
Old 08-01-2010, 08:00 AM   #5
trx73
Thanks for the advise!
Old 08-02-2010, 08:29 PM   #6
trx73
anyone else have thoughts??
Old 08-03-2010, 09:36 AM   #7
severous01
wider is better for traction, grip, braking forces and lateral forces. however, skinnier is better in wet weather...
so take your pick, although i doubt you'll notice any difference w a 10mm difference in widths unless you're a serious racer.
i'd go 205 because the tires are cheaper and you have a better selection
Old 08-04-2010, 07:56 AM   #8
trx73
I would go with 205 50 16 but I am worried they will rub. I am not lowering so I want my wheel well full so it looks like 195 50 16 unless some one can tell me that the 205 won't rub. My offset is 38.
Old 08-04-2010, 09:35 AM   #9
kimona
kimona's Avatar
With stock suspension, 205/50's will not rub with 16x7, ET38, but they will probably poke up front just a tad. If you don't mind that (and alot of YW members don't seem to care much about poke), then go with 205/50's.
Because you are running ET38, I would install 195/50/16's. BTW, 195/50's are the JDM OEM tyre size.
Old 08-04-2010, 10:44 AM   #10
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
How often do you load your car (passengers or cargo)? 205/50 may not rub unloaded but when the time comes (Loaded) it could...
CLA 250, 4MATIC
Old 08-04-2010, 10:58 AM   #11
kimona
kimona's Avatar
I run a set of 16x7, ET42, 205/50/16... and I've never had rubbing unloaded or fully loaded.
Old 08-04-2010, 11:06 AM   #12
derickveliz2
you are right, even though you have ET42 he has ET38, it's a close call.
I guess he would be OK
CLA 250, 4MATIC
Old 08-04-2010, 08:14 PM   #13
trx73
Looks like 195 50 16, Thanks everyone!!!
Old 01-02-2011, 07:24 AM   #14
trx73
16x7 +42 offset
Looking at replacing my rims again. I have 195 50 16 tires with 16x7 +38 offset currently and want to go with same size rim but with a +42 offset. Does anyone know if this will work???
Old 01-02-2011, 09:34 AM   #15
trx73
any thoughts??
Old 01-02-2011, 02:06 PM   #16
slow.yaris
Drives: 07 yaris sedan
you'll be good... 205/50 is bigger than 195/50
slow.yaris is offline   Reply With Quote
Old 01-02-2011, 02:35 PM   #17
trx73
Thanks for the input!
Tire rotation: Does TPMS recognize tire position? jcdrotos Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 03-17-2011 02:00 PM
Why does Tirerack reccomend 185/50R15s for seeminlgy ALL of their 15" rims? St_G Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 03-16-2011 06:29 AM
Tire Size and FE question GMKing Fuel Economy Forum 8 09-01-2009 09:20 PM
Auto-X/Street Tire Choice. Sabretooth Tracking, Racing, Auto-X Forum 39 05-03-2009 01:04 AM
