Old 08-08-2010, 03:55 PM   #1
nemelek
DWEED
nemelek's Avatar
Fixing a flat tire
While rotating my tires, I saw a nail head in a tire. Here is my fix.
1) Over inflate the tire.
2) Get tools ready.
3) Pull nail out and insert file.
4) Prepare plug and put rubber cement on it.
5) Insert plug and remove tool.
6) Clean off ends of plug.
7) Check the air pressure.
Although the tire wasn't leaking I would rather fix it on my terms than have it go flat on the highway.
Old 08-08-2010, 07:50 PM   #2
auxmike
auxmike's Avatar
Good job!
I came home Fri. to find a 2 inch screw in my brand new pass rear tire myself.
I used your method but did'nt ream out the hole and did'nt have rubber cement.
You DO have to run the reamer through. The hole in my tire was small and close to the sidewall. The plugs are quite wide. I was real ticked off and in a hurry,haste makes waste.
Everyone should have one of these inexpensive kits at home...
Old 08-08-2010, 10:16 PM   #3
sickpuppy1
Drives: 2010 Yaris Sedan
FYI, if you insert the plug,light it on fire for a bit and it will fuse with the rubber and pretty much guarentee a permanent seal.
Old 08-10-2010, 08:12 AM   #4
MUSKOKA800
MUSKOKA800's Avatar
Well done.
But my understanding is that radials shouldn't be plugged but rather patched on the inside. Of course this would require un-mounting the tire, patch, re-mount and re-balance. All in all a more costly process.
Tire rotation: Does TPMS recognize tire position? jcdrotos Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 03-17-2011 02:00 PM
SLIME - soluciones elegantes para la prevención y la reparación del neumático!!! pensadorcritico Central and South America 0 10-01-2007 12:19 PM
Flat Tire sambo42xa New England 2 03-12-2007 06:28 AM
Flat tire, totally ruin help David81 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-15-2006 01:54 PM
