Old 08-09-2010, 09:38 AM   #1
ktloog
Drives: yaris yr
HID help pleeeeeeeees
hi all , just i fit my hid kit today and when i start the light it's work fin and switch it off and when i start the engine and switch the light on the light stop working and when i try agine one light work and the other one no and the one it's not working just flash in the strater and some time work but must of time it's off , pls help me what i have to do please ??????
ktloog is offline   Reply With Quote
Old 08-09-2010, 10:18 AM   #2
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Are you installing High/Low HID?
Old 08-09-2010, 10:26 AM   #3
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
check crossed wires... and DRL
Old 08-09-2010, 10:40 AM   #4
ktloog
Drives: yaris yr
yes i installing H/L beam
Old 08-09-2010, 10:42 AM   #5
ktloog
Drives: yaris yr
what r u thinking about blub ! i think it's not burn it cos some time work and some time not so what i have to check ? what about the fuse mybe the problem from it ?
Old 08-09-2010, 10:47 AM   #6
marcus
toyota
marcus's Avatar
im assuming it works when the car is off..and not if its on..dont know if you guys have drl in australia..but your ballast might not turn the hid on if you have drl.due to flicker..but i could be wrong..
Old 08-09-2010, 10:48 AM   #7
derickveliz2
Did you have a direct (+) to the battery and a separate (-) to the chassis?
HID won't work when Day time Running Lights (DRL)
Yes check the fuses for now.
Old 08-09-2010, 10:54 AM   #8
ktloog
Drives: yaris yr
i have + and - in the battery and there's one (-) in chassis in the other side !!! and i dont know how to check DRL cos i dont know what's it
Old 08-09-2010, 11:01 AM   #9
derickveliz2
When you drive during the day does your lights turn on by it self?
DRL turn your lights on automatically during day light at about 50%
in my case I don't have DRL and so forth to turn the lights on during the day I have to turn the switch for lights.
does it helps?
D.
Old 08-10-2010, 01:55 AM   #10
ktloog
Drives: yaris yr
thanks that's really help , and i don't have this system in my car , till now i search for the soulation but i don't get any think !!!
Old 08-11-2010, 12:29 AM   #11
nracing
Drives: 07 yaris sedan
thats the only pic i have right now to show you a little about conecctions, its pretty simple as you can see hahaah, you have a positive wire to the battery hopefully with a 30 amp fuse, a negative to the battery, and the H4 conector, the relay gives signal to the right side so you dont need to plug anything on the right side only the wires from the relay, also on the right side u have a negative (ground), thats pretty much all.
nracing is offline   Reply With Quote
Old 08-11-2010, 10:41 AM   #12
marcus
toyota
marcus's Avatar
try switching wires..due to reverse grounding system..red to black. black to red
Old 08-11-2010, 11:05 AM   #13
ktloog
Drives: yaris yr
thanks guys for all this helpfull replys finlly i find the problem it's from the blasst cos when i switch the light on just onley one blasst work and make noise but the othe one some time work and some time not , so dos any buddy have ant seggest to solve this !!!
Old 08-22-2010, 12:33 AM   #14
brieghne
Drives: yaris sedan 2009
do you need a ground on the right relay? you can try to direct your ground from the right side to the + side of the battery, but im sure you will still have the flicker problem so get a grounding kit that has a circuit box if you're catching what i mean :D
brieghne is offline   Reply With Quote
FEELER: Possible New HID Vendor hydrohopper Cosmetic Modifications (Exterior/Interior) 17 06-11-2010 01:05 AM
XenithXenon HID Conversion Kit CorSport CorSport 0 09-03-2009 05:11 PM
KLight HID Conversion Group Buy!! $165.00 shipped!! JRT lighting Sponsors Classifieds Area 4 11-20-2006 10:47 PM
