Old 08-09-2010, 03:13 PM   #1
wsladaritz
Y4R1Z
wsladaritz's Avatar
Drives: Yaris LB
Arrow This is how it begins....
well... sorta
This is really the beginning of the end. I'm waiting on the dynamat to get here. Probably arrive in about 4 hours or so. Decided to go ahead and strip my baby
After reading some healthy discussions about sound deadening materials I don't think I'll be trying to cover every square inch of sheet metal. I'll put up some more pics after the procedural work is done
Hopefully I'll be done with this kind of work for good after this! I haven't decided if I want to try to do the doors yet or not. The Fatmat I put on the back half of the car is melting in the Texas summer sun found a couple tiny puddles under the carpet where it ran down the sides. I'm afraid to take off the side panels and check out the extent of the damage. So I might find something else for the doors.
wsladaritz is offline   Reply With Quote
Old 08-09-2010, 03:52 PM   #2
Revsson
Good luck with the deadening work. Maybe you can answer the question on this post:
http://www.yarisworld.com/forums/showthread.php?t=29753
as it appears that you removed the split seats.
Old 08-10-2010, 10:29 AM   #3
wsladaritz
Y4R1Z
wsladaritz's Avatar
Drives: Yaris LB
So 35 sq ft of dynamat and a gallon of sweat later, the sun has set and I have a iPhone camera with no flash. The best pic I could get was some sparkle off the shiny backing of the dynamat from the flashlight. So no after pics... But I took it for a spin and noticed a little less road noise. It wasn't as much as I was hoping for, guess I'll be doing the doors sometime.
Old 08-10-2010, 10:46 PM   #4
sqcomp
Roadrunner Jr.
sqcomp's Avatar
This looks familiar...
― Thomas Paine
Old 08-10-2010, 11:41 PM   #5
wsladaritz
Y4R1Z
wsladaritz's Avatar
Drives: Yaris LB
which part?
Old 08-11-2010, 03:09 AM   #6
sqcomp
Roadrunner Jr.
sqcomp's Avatar
This part:
http://www.yarisworld.com/forums/showthread.php?t=24585
― Thomas Paine
Old 08-11-2010, 03:04 PM   #7
wsladaritz
Y4R1Z
wsladaritz's Avatar
Drives: Yaris LB
nice write up sqcomp! You were extremely more thorough than I was. Good Job!
Old 08-23-2010, 09:50 AM   #8
DailyDriver
DailyDriver's Avatar
Drives: 3dr Lftback (meteorite) Manual
You may already know this... the dynamat will reduce vibration. if you want to reduce noise you will need to get a Mass Loaded Vinyl barrier down. MLV acts like the big cement barrers that go along the freeway. blocks sound. To the extent that the vibrating metal in your car is producing noise the dynamat will kill that. to block out road noise... that's the job of MLV. you can also use a Closed Cell Foam (CCF) to absorb some of the remaining noise as well.
and that is just the beginning. Sqcomp's thread is fantastic! another site that i have found helpful in my education is http://www.sounddeadenershowdown.com
just some thoughts.
DailyDriver is offline   Reply With Quote
Old 08-23-2010, 10:37 PM   #9
wsladaritz
Y4R1Z
wsladaritz's Avatar
Drives: Yaris LB
I'll check it out.. when it cools off in texas. I'm sick of working in 100+ heat while sun cooks me alive in my black yaris :(
I need to wait for a more wintery project ;)
deadening, dynamat, insulation, sound
New to Yaris ? Check in here !! VitzBoy General Yaris / Vitz Discussion 1960 02-02-2026 10:14 AM
Twin Charging whooppee777 Forced Induction Forum 68 04-28-2009 07:02 PM
And it begin's.... punch In Car Entertainment + Electronics (audio / video / alarm) 9 08-17-2007 09:34 PM
Ordered mine today... now the wait begins boris13 New YARIS Purchase Forum 1 11-10-2006 07:40 PM
The countdown begins! Slummy New YARIS Purchase Forum 6 08-30-2006 04:36 PM
