Old 08-12-2010, 07:03 PM   #1
Yaris PAVEL94
rubberizing every thing under the yaris
I JUST RUBBERIZED EVERYTHING UNDER THE CAR AND IT LOOKS GREAT I HOPE IT WORKS GREAT TO I WILL PUT PICTURE ON LATER CANT FIND MY SD CARD.THANKS
Yaris PAVEL94 is offline   Reply With Quote
Old 08-12-2010, 08:42 PM   #2
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
That was... probably a bad idea...
firemachine69 is offline   Reply With Quote
Old 08-12-2010, 10:04 PM   #3
Yaris PAVEL94
Y IS IT A BAD IDEA?
Old 08-12-2010, 10:24 PM   #4
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
Depending on where you place the rubber, it could melt as the engine heats up. Common places of extreme heat are on the exhaust manifold and the block itself.
Old 08-12-2010, 10:53 PM   #5
Yaris PAVEL94
no I make it under the trunk and by the side skirt. no place where there is heat.
Old 08-12-2010, 11:33 PM   #6
sleey0
Drives: 2008 Yaris LB
If I had a lift I would probably undercoat my car too.
Living in NW PA sucks in the winter...
sleey0 is offline   Reply With Quote
Old 11-28-2010, 10:37 PM   #7
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Exclamation
why did you do it? and what kind of material did you use?
Derick
CLA 250, 4MATIC
Old 12-04-2010, 09:47 PM   #8
doginmyyaris
Drives: 07 yaris
derick- Going by your stereo setup, I'm surprised you haven't done it. Anything to help reduce road noise....I used a couple of cans of spray-on bedliner.
doginmyyaris is offline   Reply With Quote
Old 12-06-2010, 12:14 AM   #9
derickveliz2
Thumbs up
You would need at least 3 to 5mm to really notice a difference. It would be nice if there is something special for the plastic panels. I've been looking around but nothing, not even Spectrum Sludge from Secondskin would hold to plastic, I did ask them!
It was / is on my to do list, but when I learned that MLV is more effective to block road noise I did that first.
bedliner spray it's very good to prevent rust as well! I used it many times for my Tacoma!
D.
CLA 250, 4MATIC
Yaris vs MR2 Spyder regal Off-topic / Other Cars / Everything else Discussions 36 01-25-2026 12:56 PM
Yaris TS 1.8L History and Specs CASTREX Yaris TS Talk 52 10-27-2009 05:06 PM
What the Yaris community needs to take the Yaris to the next level regal Wheels, Tires and Suspension Forum sponsored by The Tire Rack 124 04-30-2009 02:03 PM
