#1 |
![]() ![]() Drives: 2010 Yaris 3-door liftback MT Join Date: Nov 2009
rhythmic hum from engine at highway speed
Does anybody else hear this?
My manual transmission 3-door LB with about 11000 miles on it is making a humming sound that modulates with a cycle time of 3-5 seconds. I don't know the right musical terms, but here's an approximation: HUMMMMMMmmmmmm HUMMMMMMmmmmmm HUMMMMMmmmmm where the all-caps means louder and small-caps means less loud. It's a vibration of some kind that is coming from the front of the car, probably the engine or transmission, and it only occurs under load and at 55+ mph. If I push in the clutch, it stops. I know funny little noises can be very hard to diagnose, but thought I would ask. I don't think I heard this when it was new. Also, after the second oil change it is less loud. |
Crazy Oil Sniffer
Drives: MM 09 Yaris 5 Dr LB "Click" Join Date: May 2009
Mine has done that since the day I took delivery. Just as you say it only occurs at 55 plus. I have an auto which I suspected had something to do with it, but apparently not. Not a big problem for me but I too found it interesting.
#3 |
![]() ![]() Drives: '07 Yaris, '12 GLI Join Date: May 2007
My automatic sedan also has the 'highway hum'. I can't recall if it has it with the winter tires on or not. Still using the OEM Potenzas for the spring/summer/fall...
#4 |
Modded Moderator
Drives: 07 Toyota Yaris, 71 Galaxie Join Date: Mar 2007
What tires do you have? Mine did that at first with the 15" goodyears, stopped when they wore down a bit and now I only use the stockers in the winter.
#5 |
Half a Bubble Off Plumb
Drives: 2009 Yaris Sedan Join Date: Mar 2009
Most likely hum from two tires that are of slightly different diameters, or rotating at slightly different speeds from a slight curve of the road, so the hum is slightly out of synchronization, alternately reinforcing and cancelling.
#6 |
![]() ![]() ![]() Drives: 07 Yaris Sedan, Auto Join Date: Jun 2010
my auto sedan does this too. imo it's not from the tires. i think it's from the engine or transmission.
#7 |
![]() Drives: 2010 Yaris 3 Door Manual BSP Join Date: Aug 2010
I have about 500 miles on the new Yaris, and I noticed this last night. Mine is a 2010 3dr Manual and I noticed it at about 55 MPH. The noise did go away when I engaged the clutch. It kind of reminded me of a small airplane, but it was not loud enough to be an issue at all.
#8 |
![]() Drives: 2007 Yaris 5-door hatch Join Date: Oct 2006
I have the same hum on mine as well. I don't always notice it, so I wonder if it's some kind of resonance being set up somehow in the engine/tranny/torque combination. 75,000 miles on my '07 Yars.
AJAE 2007 Yaris RS Hatch, Eibach Springs and Borla Exhaust Canadian Dealer options 1981 BJ42 LandCruiser all stock Love my toys! Last edited by ajae; 08-26-2010 at 01:37 AM. |
| The Nitrous Thread | ChinoCharles | Performance Modifications | 116 | 02-16-2016 03:07 PM |
| DIY: Intake Installation | redyaris | DIY / Maintenance / Service | 53 | 08-23-2014 05:34 AM |
| engine swap update | Adriaan | Canada | 5 | 03-03-2009 06:21 PM |
| Info regarding Engine change. | sheraz2000 | General Yaris / Vitz Discussion | 5 | 01-08-2009 12:51 AM |
| Free gas for any vehicle. | ketel0ne | General Yaris / Vitz Discussion | 4 | 09-19-2006 08:07 AM |
