Old 08-21-2010, 10:53 PM   #1
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Headlight Restore
My friend's tC headlights were getting hazy and yellowish after being untouched for 5 years.
I thought I'd give this restoring thing a try - it can't get any worse than it is now.
I bought the Mother's Headlight Restore since it was on sale.
In the end, you can still see some scratches and blemishes up close, but overall, not bad for a couple of hours.
Old 08-21-2010, 11:12 PM   #2
Klink10
Klink10's Avatar
A great improvement.
Old 08-23-2010, 04:14 AM   #3
big lo
big lo's Avatar
Drives: 2007 VIOS
Mothers is a awesome product, good job.
Old 10-14-2010, 12:15 PM   #4
jstantherprsn
Drives: 01 Toyota Echo
I've used the rainx product. It worked fine, just be liberal with the lubricant and really go to town with the headlight polish, wash it then really spray down and rub in the sealant.
jstantherprsn is offline   Reply With Quote
Old 10-14-2010, 04:22 PM   #5
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I am wondering how the EuroLight product would work compared to the Mothers.
Old 10-14-2010, 06:56 PM   #6
RedRide
RedRide's Avatar
I would wager that all brands of headlight restoring products are basically just about the same with just slight variations in the prportions of the same ingrediants.
Old 10-15-2010, 03:45 PM   #7
chrisj
Hooch Brewer-Shine Sipper
chrisj's Avatar
Drives: 2009 5-dr LB
That's great! I've got a '98 Avalon that looks like it has glaucoma!
chrisj is offline   Reply With Quote
Old 10-17-2010, 09:01 PM   #8
rene0023
rene0023's Avatar
Drives: Scion FR-S 2013
Brother that stay like new. Good job.
rene0023 is offline   Reply With Quote
Old 04-14-2011, 03:58 PM   #9
HirosStorageUnit
50,000 miles, Yeah!
Drives: 06 3 door Black
I used this kit last night on the 3 door and it did a pretty decent job. I am a bit of a perfectionist but it sure did more good than bad. Our Yaris started to get bad and hazy last year and got worse almost monthly. I hope that it will last a while till I need to do it again.
That is what happens when you live in the desert at 4500 ft elevation. But thankfully we garage it most of the time.
Mods:
Factory Spoiler, K&N Air Filter, Cool Pedals, and Shifter Knob with lather turned spacer. Working on Black out badges now.
HirosStorageUnit is offline   Reply With Quote
Old 07-16-2011, 06:37 PM   #10
MadMax
MadMax's Avatar
I've been reading the reviews on Amazon.com on this product and for the most part they have been positive.
Disappointingly, the tops of my 08 LB headlights are already starting to cloud. Of course, I do live in southcentral Texas where the sun can be pretty severe. I almost bought this kit today at Walmart but decided to hold off until I did a little research. A few did claim this product made their headlights worse!
That said, we had the headlights on our 2005 Honda Odyssey "professionally" done while it was in the shop and they are not crystal clear either. I don't think that such a level of restoration is even possible...
Old 07-17-2011, 12:02 AM   #11
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
I recommend you use it ONLY if the lens is completely faded. In your case, I don't think you should use it yet. You're right - after using it, it doesn't return back to it's original state. It's still a bit blurred after I was done, but since it was really bad before, it was much better after. Another thing, I highly recommend using sandpaper with grit 1500 then 2000, wet-sanding is a must. It takes a lot longer but comes out better. You'll still see the 2000 grit scratches though.
The ones that claimed it made their headlights worse were probably because of two reasons. The lens probably wasn't that faded, but they tried it and found out that the sandpaper made scratches that the polish couldn't remove. The other reason was probably they didn't spend enough time on the sanding (esp. with 2000 grit).
Old 07-17-2011, 11:01 AM   #12
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Newsflash : ANY wax will do the same . That's right , any wax that you wax your car with will do the same thing . Personally I use Meguires NXT tech wax 2.0 .
Whenever I wax my Yaris (3 times a year : Pre and post pollen ,then again before winter ) I wax the head and tail lights .
My Yaris sits outside in the sunshine pretty much all day everyday .
Check the pics ...
Old 08-13-2011, 03:31 PM   #13
brandypup
Drives: 09 Yaris
Ah I missed this when I posted about the film on the headlights. Is there a way to prevent this from happeneing? Is waxing the answer?
brandypup is offline   Reply With Quote
Old 08-15-2011, 09:04 AM   #14
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
ive tried some plastic polish on my all red tails that got hazed up from the cheap clearcaot applied. While it tOOK away some of the mess it stillS STILL DULL....
http://www.carid.com/toyota-accessories/
site has a FEW interesting yaris items.....
ROCKLANDTOYOTA is offline   Reply With Quote
Old 08-29-2011, 11:41 PM   #15
pontingroy
Drives: good
Cloudy headlights affect hundreds of thousands of vehicles in virtually all makes of cars and trucks, domestic or foreign. Headlight restoration or repair of the lighthouse is the process of cleaning the lens of the flashlight or headlamp kits with items sometimes found in your local auto parts store. Save money on expensive replacements, which recover, quick and easy, the best thing anyone can do it without any training or special tools.
epiphone
pontingroy is offline   Reply With Quote
Old 11-18-2011, 01:44 AM   #16
henry98
Drives: toyota
Great product and great work.
henry98 is offline   Reply With Quote
Old 01-09-2012, 08:15 PM   #17
Aiko Cargo
Aiko Cargo's Avatar
Drives: 2000 Fun Cargo
That looks great. Did you wetsand at all? Definitely helps
Aiko Cargo is offline   Reply With Quote
Old 01-09-2012, 10:19 PM   #18
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Yes, wet sanded because was pretty bad. If the headlights aren't that bad, you could probably do it without sanding. This is not a permanent fix though. It has to be repeated every few months, depending on how much you drive.
DIY Projector/HID (sedan) Brian DIY / Maintenance / Service 145 02-05-2012 04:13 AM
Silverstar Ultra 9003/HB2 vs OEM headlight bulb comparison CTScott DIY / Maintenance / Service 54 02-14-2011 08:58 AM
How To Smoked Sedan Headlight -DIY zulhizainL902S DIY / Maintenance / Service 26 01-14-2011 02:12 AM
Glassylite Headlight Restoration Kit TEHxFALLEN V1.2 Photo-Video-Media Gallery 1 07-03-2010 12:51 AM
HELP! I detailed my interior, and now having a headlight issue! Astroman DIY / Maintenance / Service 4 06-08-2010 06:51 PM
