Old 08-24-2010, 01:32 AM   #1
chrisj
Hooch Brewer-Shine Sipper
chrisj's Avatar
Drives: 2009 5-dr LB
Need to Remove Fuse/Battery Disconnect?
Hi. New here. I just bought some new taillights for my '09 LB (eBay) and of course the connectors didn't match. I cut the car-side connector off and have stripped the wires, and have also done the same with the taillight side.
My question is this. Do I need to disconnect power to the taillight before connecting those wires (especially ground) together? My immediate plan is to twist the wires from the car/light together and black tape them. I just don't want a meltdown when I go a twistin'.
Thanks for any info.
chrisj is offline   Reply With Quote
Old 08-24-2010, 01:41 AM   #2
Brian
Brian's Avatar
You should always disconnect the battery when doing electrical work.
Old 08-24-2010, 03:06 PM   #3
Alezius
Alezius's Avatar
Drives: 2009 Yaris LB 5d M/T meteorite
and if your able to solder and shink wrap them instead of tape, that's even better!
by the way, wich taillights did you buy? i'd like to see a picture of it install if it's possible (close shot),
because everybody says it's not a perfect fit (interior corner) on a 2009 Hatchback. ans i'd really like to change mine.
Alezius is offline   Reply With Quote
Old 08-25-2010, 09:01 PM   #4
chrisj
chrisj's Avatar
Alezius, I got what was called a set from eBay that fit 2006-2009, but of course it was NOT a perfect fit, although I don't mind at all. Here is a picture of the ones I got.
This is a close shot that shows how it doesn't run along the car's line around the back and extends a little at the hatch, but you can't tell it at all. I installed them myself a couple of days ago and they look fine to me. I was halfway through the install when I discovered there were no bulbs in the tail lights, so I had to put the non-working factory light back in to go to the auto parts store for bulbs.
Lights work great.
Old 08-25-2010, 09:20 PM   #5
Alezius
Alezius's Avatar
thanks for the pictures! Look good on your car!
Old 08-25-2010, 09:22 PM   #6
chrisj
chrisj's Avatar
Thanks. I like the lights, but these were $60 or so, so I could change them out easily to ones that exactly fit an '09 later on. BTW, I did the twist and black tape method, so changing would be easy. I may leave these on for a year or so.
DIY - How to remove or insert a pin on the ECM Connector A21 CTScott DIY / Maintenance / Service 6 05-21-2024 12:29 PM
DIY : How to remove door panels FEINT DIY / Maintenance / Service 13 11-18-2021 02:16 AM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY Projector/HID (sedan) Brian DIY / Maintenance / Service 145 02-05-2012 04:13 AM
