Old 08-25-2010, 05:18 PM   #1
MrJester
Drives: homo
Knuckle Replacement
Okay so I am not the most mechanically inclined but I can do some DIY stuff with my car. So I took my car in to Toyota to get the typical 50k checkup / oil change. I work a hectic schedule and haveing someone else change the oil is jsut quicker and easier for me. Anywho while I was there they were doing the front end alignment and call me in to tell me that my drivers side front knuckle will need to be replaced along with anotherfront end alignment. At the moment my car is OKAY to drive but it needs to be fixed. So I have some positive camber right now on my wheel. They are telling me it is going to cost around $950-$1000 is this typical or can I find someplace that does this work cheaper or is this something I could even maybe attempt myself? thanks for the help guys.
MrJester is offline   Reply With Quote
Old 08-25-2010, 06:02 PM   #2
kou
Drives: 08 lb
To expensive shop around.
Old 08-25-2010, 06:12 PM   #3
sleey0
Drives: 2008 Yaris LB
Find a local mechanic you can trust.
Where I live, the Toyo dealer charges ~$77/hr labor and my mechanic who is prob better charges $55. BIG difference.
I would try and find the parts yourself, maybe used, and then ask your local shop for a quote.
Doing it at the deal has it's advantages mainly if you are still under some kind of warranty, but not for this I'd assume.
sleey0 is offline   Reply With Quote
Old 08-25-2010, 06:33 PM   #4
What are they saying is wrong with the knuckle? It's probably the strongest piece of the front suspension. I can see the tie rod end or the lower ball joint being bad or even the lower suspension arm being bent, but I can't imagine the knuckle failing before one of those parts.
Old 08-25-2010, 06:37 PM   #5
ctrj
Drives: 07 Yaris Sdn, 97 4Runner
X2. It's not comon to replace knuckles unless you've been in an accident. I'd ask them to show you the damage and take some pictures.
RJ
2007 Toyota Yaris Base Sedan -5 speed
SOLD
ctrj is offline   Reply With Quote
Old 08-25-2010, 07:31 PM   #6
MrJester
Drives: homo
I just know the tire has a noticeable lean to it. So from what they told me it was safe to drive I would just be doing damage to the tires.
Old 08-25-2010, 07:31 PM   #7
MrJester
Drives: homo
Ill see if I can find a local mechanic and see what they say.
PCV Valve Replacement devinlamothe DIY / Maintenance / Service 27 03-16-2013 11:06 PM
Replacement Fog light Lens Focus_Sh1ft DIY / Maintenance / Service 5 05-12-2010 12:08 AM
'09 Fog light replacement Mavix Cosmetic Modifications (Exterior/Interior) 5 10-07-2009 03:21 AM
replacement fog light switch? yrsdrgn Cosmetic Modifications (Exterior/Interior) 4 07-17-2007 04:11 PM
Thinking about making a full Intake Manifold Replacement YogiYaris Performance Modifications 26 06-07-2007 10:26 PM
