Old 08-26-2010, 08:26 AM   #1
nexxus
Drives: Yaris 2008
Question : Increase air flow
I have try to make more inlet air by use 12V cooling fan from computer.(as picture) and i fix it before sensor. But when try engine was stop.I don't know why .Anyone can solve this problem please give me a solution.Thank you.
nexxus is offline   Reply With Quote
Old 08-26-2010, 10:08 AM   #2
markitect
The biggest computer fans still only do 200 cubic feet per minute, yours is probably a quarter of that. 50 or less, which isn't enough for your car to idle (unless you have the 1.3).
markitect is offline   Reply With Quote
Old 08-26-2010, 01:42 PM   #3
sleey0
Drives: 2008 Yaris LB
Yeah, umm, that little fan isn't doing squat. lol
Good try, though! :)
sleey0 is offline   Reply With Quote
Old 08-26-2010, 01:52 PM   #4
:D it is probably blocking more air than it is pushing...
Old 08-26-2010, 08:34 PM   #5
xen555
xen555's Avatar
Drives: 3 DOORS LB
Or you can use the twin leafblowersupercharger kit like this guy
http://blog.cardomain.com/2009/05/01...-photos-found/
xen555 is offline   Reply With Quote
Old 08-27-2010, 11:20 AM   #6
nexxus
Drives: Yaris 2008
Thank for answer .But my fan it not alway runing . Normaly it not work. Intake air nomal by piston suck(engine run normal) .but when me start fan engine was stop
Old 08-27-2010, 11:33 AM   #7
henry33
Drives: yaris1.33
my opinion is that the fan has negative effect that you was expecting and it is not blowing the air but blocking it ;)
try to replace it by bigger one
henry33 is offline   Reply With Quote
Old 08-27-2010, 11:34 AM   #8
henry33
Drives: yaris1.33
Old 08-27-2010, 11:51 AM   #9
tk-421
tk-421's Avatar
Drives: 5D-07-LB
This mod does not work, and never will. I learned it the hard way...
I know it sounds harsh, but I'm trying to save you some time.
Props for the effort, though!
No idea why the engine doesn't start BTW
Engine intake air flow not smooth on certain speed and gear? ammophobia DIY / Maintenance / Service 3 07-17-2009 03:31 AM
