Old 08-29-2010, 08:16 AM   #1
ubospawis
ubospawis's Avatar
Drives: Flint Mica 2010
Maintenance Cost
1oookm/where/what/How much
Greyo
1000km /Toyota Oleya / free check / free
3000km / Toyota exit 17 / repair front passenger door / free
ubospawis is offline   Reply With Quote
Old 08-30-2010, 03:32 AM   #2
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
I'm already exceeding 5,000km, 5,700+ in total. Might go to Toyota Olaya for the check-up hopefully 1st week of sep, mafi fulos yet.
rye7jen is offline   Reply With Quote
Old 08-30-2010, 05:49 AM   #3
zsazsa zaturnnah
zsazsa zaturnnah's Avatar
Drives: 2010 Yaris YX
The same here ... Kermit has gobbled up 5,455km and hasnt gone to Toyota Hospital for service ... walang budget ang Zee Productions ... Btw, mga magkano ba ang babayaran pag nag pa 5K service? Any ideas?
zsazsa zaturnnah is offline   Reply With Quote
Old 08-30-2010, 07:31 AM   #4
syntax
syntax's Avatar
post dati ni treb tungkol sa maintennance cost ni whitey
http://www.yarisworld.com/forums/sho...434#post499434
Old 08-31-2010, 12:27 PM   #5
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
try considering the KASBAN card from TOYOTA if your car is below 5k mileage
ricepower is offline   Reply With Quote
Old 08-31-2010, 04:22 PM   #6
trebparadise
Drives: sedan yaris y
Mga kayaris, according sa ALJ they only allow 100km excess for every 5k maintenence. pag nagka trouble ang car in excess of 100km allowance, they may void the warranty kasi ang kalalabasan poor maintenance daw yun. alam nyo na. iwas pusuy sila.
i klaro nyo din dyan sa dealership nyo baka iba rin ang patakaran nila.
trebparadise is offline   Reply With Quote
Old 08-31-2010, 07:13 PM   #7
ubospawis
ubospawis's Avatar
taken from this link
5k=100sr
10k=200sr++(i lost the invoice)
15k=227sr
20k=458sr
25k=228sr
30k=388sr
total = 1601
total 1,601 doing ratio and proportion bali sa 100,000km more than 5,336 na ang gastos mo, 100k/30k x 1601 = 5,336sr, this is rough estimate only, dapat siguro hindi lalayo sa figure na ito yung KASBAN up to 100kkm
Km /MaintenanceRunning /Km per /Sr per
/ Cost total / SR /Km
5000 /100
10000 /200 /300 /33.33 /0.03
15000 /227 /527 / 28.46 /0.04
20000 /458 /985 / 20.30 /0.05
25000 /228 /1213 /20.61 /0.05
30000 /388 /1601 /18.74 /0.05
Old 09-01-2010, 01:20 AM   #8
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Whoa! Huwag naman sana.
Old 09-01-2010, 06:37 AM   #9
ricepower
ricepower's Avatar
my experience:
I got the kasban with my yaris thru ALJ. It covers the whole maintenance for 3 years or 60,000km - whichever comes first. D2 nman ako talo. My odo reading now is 48k for almost 3 years 6mos
My car is only khobar to aramco-dharan which is around 30km/day max. Nauna sa akin yung 3 years instead of 60k . I have enjoyed Kasban only on 40k major service. My brake pads(70%), wiper, air filter and belt are good at that time. Kaya ginawa ko, humanap ako ng ka yaris (jepoy) na pudpud ang brake pad for swap. Ang Toyota ALJ ay di nila papalitan ang brakepad kung makapal pa.
The best thing is that you don't pay any single halala on every service and you are entitled for discount in labor/parts.
Kung traveller ka at ang lalampas ka sa 60k in 3 years, KASBAN is best for you. Otherwise, do the normal way, pay per service.
Take note that ALJ will not honor any warranty issues if you don't send your car REGULARLY for maintenance within the 3 years or 100K. They will not honor the change oil receipts from outside.
On my part just to prolong my engine and keep it on good shape, I used to have my oil change every 2,500km or in between my 5k service with ALJ. I don't know if this may work for you and your budget and my own knowledge is change oil regularly keeps the engine in shape.
my one rial share with KASBAN
Old 09-01-2010, 01:35 PM   #10
ubospawis
ubospawis's Avatar
Originally Posted by du2efs View Post
my experience:
Sir magkano yung KASBAN? how much would it cost if you don't have KASBAN? just to compare lang kung makakatipid nga, thanks
Old 09-14-2010, 11:05 AM   #11
ubospawis
ubospawis's Avatar
Greyo
5200km / Toyota Olaya / change oil, Froton / 110sr / sept 14, 2010 / 0.022sr per km
Old 09-15-2010, 03:05 AM   #12
BlessedYaris
BlessedYaris's Avatar
Drives: Yaris Gray "Blessed"
Send a message via Yahoo to BlessedYaris
Blessed now in toyota service center for 40km general service and quoted sar1,200 for info lang po... God Bless sa ating lahat
God Bless !!!
BlessedYaris
0552829596
BlessedYaris is offline   Reply With Quote
Old 09-15-2010, 03:08 AM   #13
syntax
syntax's Avatar
1.2K SR? laki naman po ata ng quoted maintenance charges?
Old 09-15-2010, 03:10 AM   #14
syntax
syntax's Avatar
@ blessedyaris bakit po ang laki ata? ung kay treb nagpaservice si whitey ng 30K ang binayaran lang ay 388SR
Old 09-15-2010, 03:14 AM   #15
EjDaPogi
EjDaPogi's Avatar
Drives: 2008 Yaris Fleet (SilverWings)
Originally Posted by syntax View Post
1.2K SR? laki naman po ata ng quoted maintenanance charges?
baka isinama ung replacement of disc pads (?) base sa mileage. 2,300sr daw yan sabi ng kasama ko pero nong pinatingin sa labas eh puede pa naman daw linis lang!
EjDaPogi is offline   Reply With Quote
Old 09-15-2010, 03:21 AM   #16
BlessedYaris
general service po daw 40km, change oil/ oil filter/ air filter/ belt/ wiper/ spar plug/ brake fluid/ drain radiator as in complete check up & maintenance ...
God Bless !!!
BlessedYaris
0552829596
Old 09-15-2010, 03:29 AM   #17
EjDaPogi
EjDaPogi's Avatar
sabagay quote pa lang naman yon... baka bumaba pa pag sa actual na...
Old 09-15-2010, 03:29 AM   #18
EjDaPogi
EjDaPogi's Avatar
wow mali! akala ko 4,200sr. wiii!
how much does the first maintenance service cost hans_fh DIY / Maintenance / Service 25 07-05-2007 10:01 AM
