Old 08-29-2010, 05:06 PM   #1
Kal-El
Kal-El's Avatar
Unhappy My air circulation switch just broke
Well, something on my Yaris was bound to break eventually. At 91,000 miles, the first issue happened today.
I went to switch the inside/outside recirculation switch and there was an unusual tension to it. Without thinking twice, I gave it a little more pressure and it just let go. The switch is just a loose piece now and I heard the directional parts within the dash make an odd noise during the time a lightly forced the rotation. Damn. So now I cannot choose between inside recirculation or outside air. I believe it is stuck on outside air.
At least it's not a critical function but still something I want fixed. With a tight budget, it won't happen soon. And I imagine this will be a costly dash removal.
This happen to anyone else? Any thoughts?
Thanks.
Old 08-29-2010, 05:21 PM   #2
There was a member from Canada who had his fail. I sold him Crashy's diverter assembly with the mechanical cable assembly that went to the back of the knob. To change it out requires removal of the entire dash, to get the blower stack out, which the diverter is part of. You can get at the diverter from up behind the passenger glove box to see why it won't flip positions. You can also easily remove the HVAC controls panel to see what happened on that side.
Old 08-29-2010, 06:00 PM   #3
Kal-El
Kal-El's Avatar
Thanks CTscott.
I probably won't want to get into taking the dash apart myself.
How much do you think a dealer would charge - 1 or 2 hours of labor?
And are we talking about replacing a fairly cheap part or simply reconnecting a cable? I appreciate it.
Old 08-29-2010, 06:57 PM   #4
auxmike
auxmike's Avatar
Can you just reach in and move that piece by hand via the glovebox?
I always leave it on recirc.
Old 08-29-2010, 08:25 PM   #5
Thanks CTscott.
If memory serves me, the person form Canada was quoted 6 hours of labor for removing the dash and swapping the assembly.
Old 08-29-2010, 10:15 PM   #6
Kal-El
Kal-El's Avatar
That's outrageous. I don't know how I'll ever get it fixed if that's the case. 6 hours x $100 just for labor to fix a minor problem?
Old 08-29-2010, 10:25 PM   #7
Manley81bass
Manley81bass's Avatar
Drives: 07 Yaris liftback
The same thing happened to me. I just took the panel off and found that the cable had popped off the back. I reattached it and it works fine now. Quick, easy and free. Hopefully its as easy for you.
Manley81bass is offline   Reply With Quote
Old 08-29-2010, 11:10 PM   #8
Kal-El
Kal-El's Avatar
I'll definitely give it a try. Thanks
However, I've discovered worse news after going out tonight. The top left knob assembly in question doesn't light up now!! That's even more concerning and much more aggravating to go without. So if it's a mechanical cable that controls the switch, why is it affecting the backlight?
This sucks.
Old 08-30-2010, 08:07 AM   #9
This sucks.
There are two connections on the back of that knob assembly - The mechanical cable for the diverter and an electrical cable for the fan speed control. You definitely need to pop off the AC control panel and take a look at what came off and how.
Old 08-30-2010, 01:19 PM   #10
Kal-El
Kal-El's Avatar
Great news, I fixed it!!!
Pulled of the center panels and found that the assembly behind the switch had simply popped off. I re-attached and it's as good as new. All in 5 minutes. Wonder how much the dealer would have charged.
Thanks for your help guys.
Old 08-30-2010, 06:32 PM   #11
Revsson
I think you owe CTScott the other 5 hours and 55 minutes of labor cost!
Glad you got it fixed and were able to tell others. Too bad you couldn't have
taken some pics of the process.
Old 08-31-2010, 02:34 AM   #12
Hershey
found that if you sit on the opposite side when pulling out the side panels works best . That way you're at an angle where the plastic clips ( hooks ) let loose without breaking off . Had to remove center display so the loud annoying rattle it made would stop . Used sticky back felt , no more rattle . Good to see that you got it fixed .
Old 09-02-2010, 11:49 AM   #13
Kal-El
Kal-El's Avatar
Very easy to do. It only takes minutes with no tools to take the center stack apart. Starting with pic 1 snapping off the bottom piece.
Then pic 2 shows the two vertical pieces snapped off.
Pic 3 shows the climate control panel being pulled off.
Pic 4 I'm holding the control arm assembly that connects to the back of the top left knob that controls the circulation switch. That's what popped off. I simply re-attached to the back of the the fan speed assembly shown in pic 5.
Old 09-02-2010, 10:39 PM   #14
Revsson
I don't have a sedan, but thanks for the pics!
Old 07-31-2012, 09:33 PM   #15
EastCoastCnd
Drives: 2007 Yaris Sedan, Manual
Smile Thank you!
I realize this is an older thread, but I wanted to thank you for the pictures. I had the exact same problem with my Yaris but it wasn't stuck in "fresh air" mode. The windows were fogging up 20 minutes into a drive in the middle of winter (scary!).
I took it to my mechanic who fixed it and only charged me $35 for labour. Then it happened again. I don't want to be paying to have the same simple problem fixed when I feel like I can do it myself. Tomorrow morning I'm going to give this a try.
Thanks again!
EastCoastCnd is offline   Reply With Quote
Old 08-01-2012, 08:45 AM   #16
bronsin
bronsin's Avatar
If you leave the dial on recirc in my experience you will crud up the system so it smells like old socks if you run the AC very much. Which needs to be on recirc if its really hot in summer.
So my drill is run it on fresh every day for a few minutes to keep my car smelling sweetly.
If that thing didnt toggle back and forth it would be trouble!
Old 08-25-2012, 12:12 AM   #17
Tardis
Tardis's Avatar
Drives: 2007 Yaris Hatchback
The dash flies apart on these cars. They are like a snap tight model. There is a small peanut bulb for the back light it is a unique part and is a bit pricey. I paid 8 dollars Cdn for it. I think it tends to go because the fan and recirculate get used the most thus get jarred enough to pop the bulb. Glad you got it fixed. A word to the wise do not slam the recirc/fresh knob over quickly when the fan is full blast. The force of the air on the diverter flap probably puts a bit of stress on the cable assembly and will pop it off as it did to you ( luckily) or worse actually break something.
Cheers!
Tardis is offline   Reply With Quote
Old 08-25-2012, 12:16 AM   #18
Tardis
Tardis's Avatar
Good plan. You don't want to run recirc too very long in cold weather either unless you like steamy windows! Hot days I run recirc with the AC to get the cabin cold fast then go to fresh.( unless there is some stinky diesel truck in front of me! LOL)
I broke my fan switch... HELP *MAD DOG* DIY / Maintenance / Service 10 07-23-2009 10:47 AM
Intake Systems Decision Maker.. Blenjar Performance Modifications 25 09-15-2007 11:07 PM
