Old 09-07-2010, 09:15 PM   #1
Yaris0609
Drives: 09 Yaris 3 DR HB
Toyota Armest install
I used part number PTS32-52060 for this install. Very easy all you need is a phillips head screwdriver and a hammer.
Parts
Take this screw out to begin
in two pieces
this part is tricky, you need to hook the "hanger" piece into two holes in the seat brackets. then using the hammer, lightly tap them under the rails.
Assembled and in the down position
In the up position
Makes a 40 mile commute a lot nicer...
Yaris0609 is offline   Reply With Quote
Old 09-07-2010, 09:26 PM   #2
kennyanthony09
Drives: Yaris Sedan 07
can this arm rest be installed on a sedan? just want to know!
kennyanthony09 is offline   Reply With Quote
Old 09-07-2010, 09:29 PM   #3
Yaris0609
no its a lift back only part (according to TRDSPARKS).
Old 09-08-2010, 04:02 AM   #4
henry33
Drives: yaris1.33
can you take a pix how it look like in the rear ? from the rear seat point of view ? thanks
henry33 is offline   Reply With Quote
2011 Toyota Yaris Hybrid tuckevalastin General Yaris / Vitz Discussion 48 03-30-2009 07:42 AM
