Old 09-13-2010, 02:25 PM   #1
xbgod
Drives: "Burning It Down GTX2860RS XB"
Big BAD-ASS Brakes...Drilled
Too bad you closed the thread on drilled, slotted rotors. Some of the crap I heard wad retarted.
I worked as a engineer at Aerospace Components for over 10 years manufacturing brakes for racing and street driving. You can see our brakes in any Jegs, summit or NHRA magazine todate.
I run 13" front and rear drilled , slotted and zinc plated rotors. Been running this set up for 4 years on the track and the street.
Yes if you get some rotors from china they will crack and brake.
It's the material that their made of that should concern you and the process in which they are made. Not to mention if you beded your pads in correctly when you put them on as well as pedal ratio. Lots of factors when doing a brake upgrade.
Here's pics of mine after 4 years.
xbgod is offline   Reply With Quote
Old 09-13-2010, 04:13 PM   #2
xbgod
Funny you should ask. We actually make the hand controllers for the space shuttle and gyro's for Raytheon along with guided missle parts for General Dynamics.
The Racing parts were just the real passion of what we did. The company now makes more high performance racing parts than anything now.
XBG
Old 09-13-2010, 04:28 PM   #3
xbgod
Did anyone notice that on the rear brakes I incorporated the stock drum to keep my internal parking brake?
I put the drum in the CNC machine drilled and tapped it to accomodate the new 13" rotor, while still utilizing the parking brake.
XBG
Old 09-13-2010, 05:17 PM   #4
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Those are very nice
How much $ ?
Old 09-13-2010, 06:34 PM   #5
HAHA, so you just added a rotor to the outside of the drum. Then added a bracket behind the hub to accommodate the caliper?
Old 09-14-2010, 12:24 AM   #6
johnny_vitz
Drives: 2005 Toyota Echo
XBG
That's awesome. I'm guessing min. wheels are 18"/19" to run those? Box is
05' Echo Hatch - Greddy Supercharger - rear disc
johnny_vitz is offline   Reply With Quote
Old 09-14-2010, 01:13 AM   #7
xbgod
Yes you will need 17's or 18's to do this mod.
Old 09-14-2010, 02:10 AM   #8
xbgod
Gentlemen I'm not here for drama. I'm here to help with performance. Hell I even give stuff away. Lets move on.
XBg
Old 09-14-2010, 07:07 PM   #9
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
They look good, funny to think that your rotors are only 1" smaller than my wheels though.
Colin Chapman disciple
Old 09-15-2010, 12:37 AM   #10
xbgod
It's been a great kit. I didn't change the M/C or proportioning valve or even need to add a residual valve.
Yes on the rear kit we drilled out the back side of the drum to keep the P/B and just added a bracket to the housing end.
The front was a complete change but still very easy to install. The calipers are 6061 billet aluminum. They are full floating like a stock caliper so you can't feel run-out like you would on a fixed drag racing caliper. Which is much better for street use anyways. The brakes are so large I doubt you would warp a rotor anyways.
Cost for front and rear: 3,000.00
XBG
Old 09-15-2010, 03:03 PM   #11
why?
why?'s Avatar
Drives: Yaris LB
XBG
WOW! They even cost more than my wheels! And that isn't easy when you are running these
Old 09-15-2010, 03:26 PM   #12
xbgod
Nice wheels..........
I was going to use a set of Volks for this new build but Got such a good deal on a set of 5Zigen wheels I couldn't pass it up.
I just attached a pic of the wheel from Wheels Next. it's that exact color in 18". I haven't even been home to see them. Which goes for the other thousands in parts I haven't seen either.
XBG
Old 09-15-2010, 07:54 PM   #13
why?
why?'s Avatar
Drives: Yaris LB
Wow those are pretty!
I should've found something more sensible, but those things weigh so little that I couldn't pass them up.
Metal scratching from brakes alt_k1ll3r DIY / Maintenance / Service 16 02-11-2010 12:04 AM
ADVANS and Big Brakes Package emanansala.com Items for Sale by private party 12 01-25-2010 05:21 AM
Bad Driving Techniques Altitude General Yaris / Vitz Discussion 10 02-10-2009 05:26 PM
Big Bad Oil Co. boxerboy Off-topic / Other Cars / Everything else Discussions 10 09-04-2006 12:46 PM
