Old 09-14-2010, 08:06 AM   #1
teddy
Drives: 2008 5-door hatchback
Send a message via MSN to teddy
What is needed to add a second keyless entry remote?
My Yaris came with 3 keys - 1 keyless entry and 2 regular. I am hoping to get a second keyless entry remote, or convert one of my 2 regular keys to a remote. I've found CTScott's guide on how to program them, but I'm not sure what to get in the first place!
I see some listings on eBay like this one which is a "remote key replacement shell" so I figure this isn't the only thing I need.
But the same eBay store has these Transponder chip key which looks just like what I have now.
Am I even looking in the right direction?
Thanks & Cheers
teddy is offline   Reply With Quote
Old 09-14-2010, 06:12 PM   #2
M4One
Drives: 2007 Toyota Yaris Hatchback
The replacement shell is just the shell and nothing else. That's what I just purchased to replace my mashed up buttons. It has no electronics. I believe you will need the transponder chip key.
M4One is offline   Reply With Quote
Old 09-14-2010, 06:20 PM   #3
teddy
I figured as much, but I hope there is someone here who knows what part I need to look for the remote.
Old 09-14-2010, 07:59 PM   #4
Does you car have the engine immobilizer?
Old 09-14-2010, 08:08 PM   #5
teddy
I believe so. I think that's required on all cars up in Canada unless I'm mistaken.
It's also worth noting that I already have one remote, but my wife uses it.
Old 09-14-2010, 08:17 PM   #6
The part number is: 89070-52850
Here's the first place that comes up doing a quick search:
http://www.autotransponder.com/2009_..._entry_remotes
Old 09-15-2010, 08:29 AM   #7
teddy
What information should I ask about before bidding on something like this?
Part#, FCC ID, etc?
http://cgi.ebay.ca/NEW-TOYOTA-CAMRY-...item3a5eb16296
Old 09-15-2010, 10:16 AM   #8
Part#, FCC ID, etc?
The HQY12BBY from the listing is the FCC ID. You can look at the back of your other one (or you might have to pop the cover) to see what the FCC ID is of yours. I don't believe that you will find that that one matches, as the Camry key's have different part numbers.
Old 12-11-2010, 02:40 PM   #9
teddy
Alright I'm back to wanting to do this.
I found a remote key with identical codes on the inside. Before I hit Buy It Now I want to confirm that getting it cut won't be a problem. Everything needed is already in the chip correct? Once it is cut and programmed using the guy it will work?
Old 12-11-2010, 06:42 PM   #10
You'll have to make the car learn the remote, as well as the transponder key. The procedure for both have been posted in some other threads.
Old 12-11-2010, 08:13 PM   #11
teddy
Does this do what you are referring to? http://www.yarisworld.com/forums/sho...19&postcount=6
Old 12-11-2010, 09:28 PM   #12
Yes. That's the part for the remote. There's another section for adding a transponder key.
Old 12-11-2010, 10:38 PM   #13
teddy
hm.. having trouble finding the section about the transponder key. I will have to spend some more time digging around before my key gets here!
EDIT: I found this http://www.toyotaownersclub.com/foru...howtopic=85266 (post #3). I will give it a shot.
Old 12-28-2010, 09:49 PM   #14
teddy
Got my key - anybody know if it is possible to transfer my current key blade with the uncut key blade on the new remote key? It might be easier than trying to program the keys. I'm afraid of accidentally hitting the erase code to remove all my current keys!!
Edit: I don't think it's possible now. I see the transponder is in the key fob itself, not the blade.
Add remote to factory keyless. imknotright DIY / Maintenance / Service 50 03-24-2018 12:10 PM
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 01:32 PM
Power door lock keyless entry and remote start rizaydog In Car Entertainment + Electronics (audio / video / alarm) 10 07-20-2009 04:14 PM
What is the FCC# for the keyless entry remote (3 Door)? chingyeunglo General Yaris / Vitz Discussion 0 08-01-2007 09:25 PM
Should I add remote key less entry? Options YotaYarisUSA General Yaris / Vitz Discussion 13 05-02-2006 05:06 PM
