Old 09-16-2010, 02:40 PM   #1
yaris2010RS
yaris2010RS's Avatar
winter prep....
okay, i know its early but i need to start preparing for winter. im not in a situation to make my car a sleeper (parked all winter) so i need to prepare to drive it in snow. currently its sitting on the ground with stock rims and tires.
my main question is what is better for the winter (if it matters at all), raise the coilovers all the way up or put the stock suspension back in the car?
my original thought was to just raise it up on the coilovers but after reading info about lowering kits and the pros and cons to springs vs. coilovers (if u lower ur car with springs and dont change shocks they will work at bottom end and wreck them), i was wondering if the same applied to the higher end of the coilover shocks.......
also i know a big thing too is to change to winter tires, i will see how the first snowfall goes and decide from there.
also how important is it to change to stock intake? i have also been considering that.
we have lots of time before winter becomes a reality so any input is appreciated.
Old 09-16-2010, 02:54 PM   #2
yaris2010RS
thx for quick reply. the adjustment issue im not too worried about, when i put the kit in i coated it with ani-seize. im more concerned about the shock wearing due to over extension of the shock
Old 09-16-2010, 02:55 PM   #3
127.0.0.1
winter tires and as much lift as possible
Old 09-17-2010, 08:26 AM   #4
teddy
Drives: 2008 5-door hatchback
Send a message via MSN to teddy
I can tell you winter tires were like night and day. Everything on my Yaris is stock and I think it generally does fine in the snow. Not fabulous like on ice or that freshly fallen slushy stuff, but it's not bad. I have never been stuck.
teddy is offline   Reply With Quote
Old 09-17-2010, 02:49 PM   #5
yaris2010RS
i have only been stuck once and really it was cuz i went where no yaris should go.... and that was snow a foot deep with a hard surface on it..... when the wheels broke it....omg.... 2 hours later iu was free. lol. dont think winter tires would have helped me.
has anyone ever driven a lowered yaris in the winter? how bad could it be.....
Old 09-17-2010, 04:11 PM   #6
landrym28
3,300+ at one point.. >:(
landrym28's Avatar
Drives: 2010 Hatchback RS
My car isn't lowered, nor have I driven a winter in a lowered car, but I'm sure hitting a nice big piece of "What you thought was snow was actually a hard piece of ice" wouldn't be pretty!
Old 09-17-2010, 04:42 PM   #7
sleey0
Drives: 2008 Yaris LB
This will be my first winter in my yaris. I just installed tokicos and nf210s sono going back now. I will just try my best to keep everything cleaned at least once per week.
My injen intake will stay on as I doubt it will hurt anything.
I will say that winter tires are an absolute must, at least where I live.
sleey0 is offline   Reply With Quote
Old 09-17-2010, 10:58 PM   #8
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
driving a low car in snow is not fun. I had a Saab Viggen, and my front lip was used as a snow plow many times. By the end of my time with it my front bumper was attached by wire, because it always hit something, and constantly fell off. It was a ton cheaper using wire every 6 months or so than replacing clips.
just to show how low it was.(not my car or pic. i wish i could take pics like that.)
Colin Chapman disciple
Old 09-18-2010, 11:54 AM   #9
sleey0
Well, I will be parking in plowed areas whenever possible. If I have to walk a bit so be it;)
Guess it is a good thing I went with NF210's instead of the MI springs lol.
Old 09-18-2010, 11:59 AM   #10
BailOut
Steals terrorist's lunch
BailOut's Avatar
I live in an area of higher elevation that sees 300-400 inches of snow each year. I just run an all season tire year round (right now I'm on Kumho Solus KR-21s) and keep Spikes Spiders handy for the deep stuff.
- Brian
Share the Road
Old 09-18-2010, 01:57 PM   #11
yaris2010RS
what are spike spiders?
Old 09-18-2010, 03:47 PM   #12
sleey0
Snows a lot.here and with cheap winterforce tires i never needed any studs or spikes.
Old 09-18-2010, 11:01 PM   #13
BailOut
BailOut's Avatar
http://www.spikes-spiders.com/
I run the Compact version, as do others here on the forums.
- Brian
Share the Road
Old 09-18-2010, 11:46 PM   #14
sleey0
lol
I live in a pretty damn snowy area but you'd have to be in the Rocky mountains to need those! hahahah
Old 09-19-2010, 12:34 AM   #15
BailOut
BailOut's Avatar
The Rockies, or in my case the Sierra Nevada mountains.
- Brian
Share the Road
Old 09-19-2010, 05:52 AM   #16
nemelek
DWEED
nemelek's Avatar
I always try to get a coat of wax before the snow falls.
Old 09-19-2010, 06:59 AM   #17
yaris2010RS
do those count as "chains" on tires?
Old 09-19-2010, 07:07 AM   #18
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Oil spraying the whole car is a good idea at this time of year,as oil spraying seems to be a Quebec/Ontario phenomenon you are in luck as i'm sure theres a Krown outlet or something similar somewhere close by..
http://www.krown.com/#process/
Winter Gas Causing Drop in MPG? MadMax Fuel Economy Forum 66 03-21-2010 04:46 PM
Do you get about 4 MPG less during winter ? paraganek Fuel Economy Forum 24 05-18-2009 09:52 AM
Winter tire width Ironphil Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 04-21-2009 01:47 AM
Official "CASTREX" WINTER THREAD CASTREX Off-topic / Other Cars / Everything else Discussions 13 10-24-2008 08:19 AM
