Old 09-22-2010, 03:06 PM   #1
jmk1983
Drives: 2006 Yaris RS 3Dr
Replacing factory fog lights?
Replacing factory 2006 Hatch Fog Lights, a they have both been smashed by rocks. I bought them off of EBay and they told me it will be a direct fit, no wiring required, just pop out the old ones and pop in the new ones.
Anyone done this?
jmk1983 is offline   Reply With Quote
Old 09-22-2010, 04:04 PM   #2
I did just the opposite and it worked fine. I had a set of aftermarket ones and picked up a set of real OEM ones from someone, so I swapped those in. Same connector, same mounting - No problem.
Old 09-22-2010, 04:41 PM   #3
jmk1983
So it should really be that easy? The seller said there are no instructions as it is made for a direct fit.... Fingers crossed I guess!
Old 09-22-2010, 09:47 PM   #4
MadMax
MadMax's Avatar
The biggest pain is getting to them...
But I have one with a cracked lens that I have been meaning to replace for a while. I've even got the replacement from Garm, but since it's not leaking moisture in it (yet), I'm gonna hold off until it does.
Cheers! M2
Old 10-13-2010, 04:39 PM   #5
M4One
Drives: 2007 Toyota Yaris Hatchback
I'm looking into getting a pair of bulbs off ebay, too. I'm looking towards getting some cheap no names http://cgi.ebay.ca/ws/eBayISAPI.dll?...=STRK:MEWAX:IT, but I'm not entirely sure whether I should go with a name brand or not. I'm also not entirely sure if I'm going to get the yellow bulbs or something brighter.
M4One is offline   Reply With Quote
Solar powered High Bright LED lights replacing the fog lights alan1828 Canada 10 05-14-2010 12:34 AM
Fog Lights Poll Reeves360 Cosmetic Modifications (Exterior/Interior) 14 12-27-2009 02:00 AM
Disabled DRLs and Factory fog lights DARKYARIS DIY / Maintenance / Service 21 05-01-2007 05:32 PM
can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. fantabulousbaby Cosmetic Modifications (Exterior/Interior) 22 08-29-2006 01:13 PM
