Old 09-25-2010, 02:25 PM   #1
detroiter
detroiter's Avatar
Seafoamed her today
So finally decided to do the Seafoam treatment. I've done the
oil and gastank method in the past but never through a line into
the engine. So paid about $7.50 for a can of it and went home,
poured half of it into a plastic cup. SLOWLY let the hose take it
up into the engine, while keeping my finger at the end of the
hose so that way it keeps suction and won't stall out, letting
my finger move so the hose can suck up the Seafoam little at
at time.
After the cup was emptied, I let it sit for a half hour or so then
came back out and poured the other half of the can into the cup.
Same thing, just let the hose suck it all up. But this time around,
from the Seafoam that was sitting in the car, all kinds of nasty
smoke started coming out. Some of it smelled pretty foul too.
So after emptying the last of the Seafoam into the car, I hopped
into the car and revved it up and held it there. Boy was their
some sort of smoke show! It was whitish in color at first then
it took on a darker hue, not black but grayish in color which I'm
guessing was all of the carbon buildup. So after the smokeshow
died down a little bit, I took the car out for a drive. Stuck to the
sidestreets first because when you get on it, their was still
a good amount of smoke blowing out the rear. After driving for
a while it all died down and I headed home.
Overall initial impressions is that their must have definitely been some
carbon buildup because their was some nasty, greasy black stuff
left on the end of my muffler. The engine response too has been much
improved, as well as the engine running quite a bit smoother and quieter.
Anyone else have similiar success stories with Seafoam?
Old 09-25-2010, 02:44 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I have always poured it into the gas tank. I know that does something different, but it has always seemed to do well by me. How many miles you have on your ride Detroiter?
Old 09-25-2010, 02:50 PM   #3
detroiter
detroiter's Avatar
I have a tad bit over 80,000 on the odometer.
Old 09-25-2010, 04:27 PM   #4
Clintondmb
Drives: '08 3DrLB.
I have doen the seafoam a few times to my Corolla. The bets though was the first seafoaming I did was with a friend in the advanced autoparts parking lot. We had never done it before.... we took the air cleaner off his old CARBURETED nissan pickup. We had plumes of white smoke coming out of the thing. With the volume of the smoke coming out it also helped up see that he had a small crack in his header. In his we just dumped it in the top and held the gas down slightly to keep it from stalling out.
Clintondmb is offline   Reply With Quote
Old 09-25-2010, 11:52 PM   #5
jonismyname
Drives: 08 liftback 5spd
seafoam has saved me from removing/cleaning carburators on older motorcycles a few times... an unpleasent task.
main ingredient is NAPTHA, which is a fuel based solvent. i believe it also contains alcohol, which should be taken into consideration when adding it to fuel (most already are 10% alc...)
oil change places will charge you $100 for what you just did...
jonismyname is offline   Reply With Quote
What did you do to your car today? Justin220 Off-topic / Other Cars / Everything else Discussions 150 06-04-2015 11:47 PM
My Yaris turns 4 today! Astroman General Yaris / Vitz Discussion 7 07-30-2010 08:29 PM
Checked out honda today for comparison..not impressed!! munchkin Canada 1 05-23-2009 07:06 PM
Got my second door ding today! bugnuts General Yaris / Vitz Discussion 5 03-14-2007 10:07 AM
Placed my order today drdavidr4u New YARIS Purchase Forum 8 06-19-2006 03:43 PM
