Old 09-28-2010, 02:25 PM   #1
ApolloX
Drives: 2007 Yaris 4 Door
Instrument Panel Light out?
I havea 2007 4-door Yaris. The other night I was driving and I noticed if I turn my light panel dial (shown below) all the way up, the RPM/MPG dashboard items go completely black. The clock stays visible.
First off, am I correct in assuming this is a problem? I thought turning the dial all the way up, put it at maximum illumination, but I could be wrong.
Second, are their two lights involved? The dashboard is visible at non-maximum illumination, but non-visible at max. This would sort of make sense if there were two lights involved and it was flipping between the two at max. Is this correct?
Finally, am I looking at a fuse issue, a lightbulb issue, or an electrical problem? Any tips?
ApolloX is offline   Reply With Quote
Old 09-28-2010, 02:39 PM   #2
BLH
Drives: 2007 Yaris Sedan
If you turn it all the way up until it clicks. Some lights go back off.
I usually have mine up to just before it clicks.
Old 09-28-2010, 05:56 PM   #3
bankrobber
Drives: 2007 Yaris Hatchback
When you push all the way up it is supposed to be brighter. I use mine when raining and I need to turn on headlights. If I wear sunglasses I can see display unless I turn it till it clicks. I would guess it is all one bulb.
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
Question about replacing Instrument Panel!! Wowzers78 General Yaris / Vitz Discussion 0 03-18-2010 09:25 AM
Door Panel Light charleschia1986 In Car Entertainment + Electronics (audio / video / alarm) 8 10-20-2009 12:27 PM
