Old 10-01-2010, 01:45 PM   #1
bizzlebaby
bizzlebaby's Avatar
Drives: 4 Dr 07 Sedan
HELP - five days constant rain now chck engine light on
Didn't have the car in any high water jus been raining for five days. Left work yesterday and after five min driving it stalled. Ran a lil rough. Today I turned it on was a lil rough at first now the check engine light is on. Had an oil change 2500 miles ago..... what to do?
bizzlebaby is offline   Reply With Quote
Old 10-01-2010, 02:07 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Do you have a cold air intake or short ram intake? Have you checked to be sure that there isn't something causing too much moisture to get to your intake?
Old 10-01-2010, 02:11 PM   #3
Go to Autozone or some such place and get the check engine code read. Only way you're gonna know what's going on.
Old 10-01-2010, 02:19 PM   #4
bizzlebaby
bizzlebaby's Avatar
Just the oem air box... ok I'm near a dealership but in betta judgement ill stop at autozone ...
Old 10-01-2010, 02:42 PM   #5
Although I don't live in the States, it is my understanding that Autozone will read the codes for free. Dealership is going to charge you a ridiculous diagnostic fee.
Old 10-01-2010, 02:42 PM   #6
bizzlebaby
bizzlebaby's Avatar
Ok so I got it read at autozone ... 4 cylinder misfires. Only at 35000 miles. Tune up?
Old 10-01-2010, 03:39 PM   #7
Astroman
Modded Moderator
Astroman's Avatar
You shouldn't need a tune up with that little miles... However since your still under warranty and you know what the CEL is I'd head to the dealer.
EDIT: I just saw you have a 07 so I'm not sure what your situation is on your warranty. Mine ran out in less than 2 years as I hit 36k miles.
Old 10-01-2010, 03:51 PM   #8
YarisSedan
Drives: 08 Yaris Sedan
Most likely if it happend after heavy rain water could have got down into the spark plug cylinder. Ive seen this happen a lot since my shop is right down the street from a detailer where they steam clean engines. We remove the coil and its soaked in water. I would try removing coil number 4. That would be on the farthest from your belts on the right side. It should be only a 10 mm bolt and just unplug it and it should pop out. If there is no water then swap that coil with cylinder 1 with is the opposite side. Then drive it for a few days. Have the codes check again if it shows the miss fire now as cylinder 1. Simple purchase one from the dealer and replace it yourself. You just saved yourself a ton of money.
However if the code still shows cylinder 4. Then i would recommend taking it to someplace to have it diagnosed as there are several other possibilities
Old 10-04-2010, 06:28 PM   #9
bizzlebaby
bizzlebaby's Avatar
ok thanks
Old 10-08-2010, 07:40 PM   #10
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
did you mean all 4cyls misfire or #4cyl misfire?
if all 4 misfire might be ecm related
if #4cyl misfire could be faulty coil
OTA'sTOY is offline   Reply With Quote
Old 10-08-2010, 08:15 PM   #11
sleey0
Drives: 2008 Yaris LB
Yeah the cowlmight not protect the ecu in REALLY heavy rain.
But he most likely have more codes if the ecu is failing.
"And that goes for any of you, never get put down from someone who gets jealous of you; build it and prove them wrong. There will always be haters and naysayers but those are also the ones who's cars are worth less than my seats."
xbgod - 9/23/2010
sleey0 is offline   Reply With Quote
Check engine light on kcty DIY / Maintenance / Service 19 03-10-2012 08:54 PM
Check engine light Geelmeel DIY / Maintenance / Service 7 11-28-2009 11:32 PM
Check engine light flashes during high reving AlphaFox DIY / Maintenance / Service 40 08-21-2007 01:43 PM
Check Engine Light Question falkor_99 General Yaris / Vitz Discussion 11 07-22-2007 05:15 PM
service engine light @ 9000 mi? dandj DIY / Maintenance / Service 21 01-03-2007 12:30 AM
