Old 10-03-2010, 06:16 PM   #1
soloecho2
soloecho2's Avatar
Drives: 2004 Echo HB
Chicken lift
Is there an easy way to cure the back end from coming around. I am not sure if it's as simple as carreing to much speed into the corner or if it me lifting once the car starts to push. Any pointers would be great.
Thanks again
soloecho2 is offline   Reply With Quote
Old 10-03-2010, 07:01 PM   #2
You have oversteer?
What is your suspension set up?
Late braking into the corner, or even lifting after starting your turn can cause that. Trying doing ALL of your braking before you turn the wheel, and see how that feels.
Old 10-03-2010, 07:20 PM   #3
soloecho2
soloecho2's Avatar
Eibach pro kit strut tower brace rear sway bar. 195/50/15 tires. It was on an oval got about a third of the way through the corner before the back end let go.
Old 10-03-2010, 08:55 PM   #4
Are you lifting off the gas when you feel the back end coming around?
Old 10-03-2010, 10:16 PM   #5
soloecho2
soloecho2's Avatar
Not sure that's the problem. The whole chicken or the egg thing. I think it starts to go then I lift.
Old 10-04-2010, 01:04 AM   #6
What tires, exactly? And what tire pressure were you running when this happened?
Old 10-04-2010, 08:13 AM   #7
That's the majority of the problem. You have look where you want to go and mash the gas. On a FWD is essentially impossible to spin while under power. As long the front wheels are in the direction you want to go, the front end will keep pulling you in that direction.
I've had the back end pushed out nearly 90 degrees while racing and still recovered. I was at full lock in the direction I needed to go and had my foot to the floor.
Old 10-04-2010, 08:42 AM   #8
markitect
I'd play with tire pressure, you can do more then you'd think.
markitect is offline   Reply With Quote
Old 10-04-2010, 10:12 AM   #9
soloecho2
soloecho2's Avatar
Falken 912s 38 in the front 40 in the rear.
Old 10-04-2010, 10:45 AM   #10
sickpuppy1
Drives: 2010 Yaris Sedan
If your loosing it a third of the way through the corner. it sounds like you went into it too hot. I dont race, just a watcher, but I'd always heard you slow just as you approach the corner, and back into the gas the second half of it, past the apex.
And I could be full of it too!
Old 10-04-2010, 11:55 AM   #11
Jason@SportsCar
FWD - when all else fails, floor it.
http://www.youtube.com/watch?v=gPCGn...eature=related
Old 10-04-2010, 06:17 PM   #12
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
that clip should be required watching for everyone who drives a fwd car.
Colin Chapman disciple
Old 10-04-2010, 08:20 PM   #13
That was basically what I experienced, but on ice LOL.
Old 10-04-2010, 09:36 PM   #14
jcemitte
Drives: 09 yaris sedan
well that concludes this thread from the champ himself
when in doubt, power through out.
jcemitte is offline   Reply With Quote
Old 10-04-2010, 10:34 PM   #15
soloecho2
soloecho2's Avatar
Wow that's what I thought but the concrete wall were a little intimidating.
2010 Yaris lift eric81 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 10-13-2015 08:57 AM
Sedan Trunk Lift eggyolk808 DIY / Maintenance / Service 9 09-11-2013 06:19 PM
Finally bought a lift CTScott DIY / Maintenance / Service 26 09-28-2010 09:09 AM
hood lift? Qmobile Cosmetic Modifications (Exterior/Interior) 19 08-14-2010 09:35 PM
WeSellCarParts.com // Redline Tuning Hood Lift! WeSellCarParts WeSellCarParts 45 12-18-2008 07:12 PM
