Old 10-05-2010, 11:09 PM   #1
kharrar
Drives: Tacoma
Cruise Control for manual trans Yaris $150
Brand new in the box cruise control ; Rostra Precision Controls part number 250-1797 for manual trans only. Can send pics; $150 plus $8 shipping; karl@northink.com
kharrar is offline
Old 10-07-2010, 12:21 PM   #2
henry33
Drives: yaris1.33
can you post the pix ? can this be mounted on the european yaris ? i have 2010 1nr-fe model .
thanks
henry33 is offline
Old 10-07-2010, 12:46 PM   #3
thanks
Henry, I shot a PM to Kara, when I saw this posted, but forgot about you. I believe that the Rostra aftermarket cruise control will work on European Yaris, since it has its own controls, and simply overrides the gas pedal input to the ECM (which is wired the same on US and European Yaris). It requires a bit of work to install, but for this price, if it works, it would be the cheapest option for you.
Here's the install manual for it:
Rostra - MT - 250-1797.pdf
CTScott is offline
Old 10-07-2010, 04:27 PM   #4
henry33
Drives: yaris1.33
looks little bit difficult but maybe I can do that ;) i will contact manufacture whether this will work on European yaris ;)
thanks Scott ;)
henry33 is offline
Old 10-09-2010, 12:09 PM   #5
white_rice
white_rice's Avatar
Drives: 2008 Toyota Yaris LE
Send a message via MSN to white_rice
Hello,
I have a 2008 Yaris LE Hatchback 5 spd. without cruise control. Is this the best and cheapest way to add this feature?
white_rice is offline
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 11:59 AM
