Old 10-06-2010, 12:49 AM   #1
husaynkhan
Drives: new vitz
SCrreeech
Hi dearest members, my greetings. I have a Yaris HB ,auto year 06. Since i have bought it , every morning i starts it, it screeches for 11sec and then it starts. I dont know where the problem is? Can anyone help me.........
husaynkhan is offline   Reply With Quote
Old 10-06-2010, 01:01 AM   #2
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Is it a grinding screech or a high pitched whirring screech
Old 10-06-2010, 08:16 AM   #3
My guess for a screech would be the serpentine belt. Since it is an '06, this belt has either stretched and needs to be re-tensioned, or it has reached end of life and needs replacing.
Old 10-06-2010, 09:33 AM   #4
detroiter
detroiter's Avatar
Yeah, could be the belts being old and worn with moisture on them.
Old 10-06-2010, 09:41 AM   #5
big lo
big lo's Avatar
Drives: 2007 VIOS
Yep, I agree the its the belt. First check the belt if its worn or a bit torn change it but if its good then you can loosen the alternator a bit to tighten the belt, good luck buddy
Old 10-13-2010, 11:30 AM   #6
husaynkhan
Drives: new vitz
wooow thnx for ur reply but when in the morning when am going to start the car for the first time, it does that grindd for 11 sec and then starts. Its an 06 car,auto.
so if someone can tell me where this belt is found or any image to show. it would be of great pleasure.
Old 10-13-2010, 11:33 AM   #7
husaynkhan
Drives: new vitz
or is it the timing belt?
Old 10-13-2010, 05:02 PM   #8
big lo
big lo's Avatar
Drives: 2007 VIOS
Nah man its not the timing belt, just look for your alternator belt you only have one that is visible push down on it and you will notice that the belt is not tight and just loosen the alternator screw and tighten that baby up and that will resolve your problem
Old 10-13-2010, 06:53 PM   #9
DARK AGE 53
Drives: 2009 Yaris Onyx
are you saying it takes 11 sec before it starts, and while it's trying to start it makes screeching noise?
DARK AGE 53 is offline   Reply With Quote
Old 10-13-2010, 07:05 PM   #10
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Our cars have timing chains, IIRC. At least, all the japanese made ones do.
Old 10-13-2010, 07:13 PM   #11
DARK AGE 53
reading over husaynkhan post it sounds more like a starting system problem.
Old 10-13-2010, 07:48 PM   #12
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
its just the belt...try belt dressing,,or just replace it..but make sure you get someone to do the proper tension eitherwise its still gonna squeel even if its new..
Old 10-13-2010, 11:30 PM   #13
big lo
big lo's Avatar
Drives: 2007 VIOS
Ain't that the truth, I hope he does the job instead of paying someone to do it its simple even a cave man can do it lol
Old 10-14-2010, 09:35 AM   #14
This is what is now making the OP's original post confusing. If the noise is occurring before the engine has even caught, then the belt is not the issue. If the noise occurs for 11 seconds after initial start, then we are still looking at a possible belt issue.
OP - please clarify when exactly you experience this noise. Also, you have described your issue as both a 'grind' and a 'screech'. Which is it? The belt will not cause a grinding sound.
Old 10-17-2010, 08:21 AM   #15
husaynkhan
Drives: new vitz
ya DARK AGE 53 thas wat am telling
Old 10-17-2010, 08:22 AM   #16
husaynkhan
Drives: new vitz
can anyone post a pic of this belt u alll are saying......
Old 10-17-2010, 08:28 AM   #17
http://www.yarisworld.com/forums/sho...rnator+tension
Old 10-17-2010, 05:25 PM   #18
DARK AGE 53
o.k, so it takes 11 sec for the engine to start and while it's cranking over it makes the screeching noise, now once the engine fires up does the noise goes away or does it continue making the screeching noise.......if the noise stops it's probably the starter and not the belt.
