Old 10-06-2010, 01:43 PM   #1
gliwa86
watev
Drives: toyota yaris 3dr
Question yaris 5 speed manual trans ????
i have 34000 miles on my 08 yaris hatch what should i do to the trans should i just change the oil like normal or is it better to do a comlplete flush, whitch one will be bettter for the4 life of the car????? please help and i grind my gears quite allot i try not to but in chicago traffic its kinda hard not to
gliwa86 is offline   Reply With Quote
Old 10-06-2010, 02:14 PM   #2
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Since you grind your gears, you should change it frequently. The sooner the better.
Old 10-06-2010, 02:15 PM   #3
mryaris
Drives: 2010 Carmine Red hatchback
At 34,000 miles you shouldn't have to do anything. That said, draining it and re-filling should suffice....no need to flush anything.
mryaris is offline   Reply With Quote
Old 10-07-2010, 12:00 PM   #4
gliwa86
watev
y not does not the flush do a better job at cleaning all the gunk???? and build up
Old 10-07-2010, 12:43 PM   #5
kimona
kimona's Avatar
Drives: 2014 White VITZ
If your car is still under warranty, consult with your Toyota dealer for recommended tranny oil change intervals. Grinding gears, even in heavy Chicago traffic, is not normal. Respectfully, perhaps you should consider a driving course to learn how to properly drive a stick shift.
Old 10-07-2010, 01:07 PM   #6
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
I think some of it is due to the Yaris' touchy clutch. I know I've done the grind more times than in other manuals I drive/have driven.
Old 10-07-2010, 06:58 PM   #7
mryaris
This is true...I have scratched a few gears in my Yaris and I've been driving sticks for 20+ years. Embarrassing as hell when it happens!
As for the OP.....I just don't see there being much "gunk" built up in only 34K miles so IMHO you would be wasting your money. Now if you grind the gears on every shift every time you drive then yes....you probably have all sorts of crap in the tranny case (metal shavings, etc.) and a flush might be warranted.
Do what you need to do, but any flushing of the engine or trans at such a low mileage is atypical.
RPM at 60 mph 5 speed manual mark schofield DIY / Maintenance / Service 13 10-08-2011 12:14 AM
Max Speed in Each Gear for 5 speed man. Yaris with no tach?? 09TRD General Yaris / Vitz Discussion 53 09-24-2010 04:18 AM
