Old 10-07-2010, 01:23 PM   #1
blacks
Drives: toyota yaris sedan
INTERIOR FLOOR SOAKING WET
Hi
I have a problem every time it starts to rain the floor in the
interior is soak does anyone else have that problem or is it just me.
If you have a solution to it would you mind sharing it please because it's
starting to bug me
blacks is offline   Reply With Quote
Old 10-07-2010, 01:28 PM   #2
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Have you checked if you have all the rubber plugs in place at the bottom? Sometimes car dealers forget to put them on...
Old 10-07-2010, 02:49 PM   #3
blacks
Well i check all of them and there in there rightfull place
but i just put some silicon around them but i wanted to know
if this happened to anyone else and what was there problem
Old 10-07-2010, 03:50 PM   #4
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Can you notice where it starts?
Old 10-07-2010, 04:06 PM   #5
blacks
well no not really because it was mostly the 2 rear floor that was wet
Old 10-07-2010, 04:16 PM   #6
33OH
Drives: '08 Yaris
Mine does the same thing, still unsure as to why.
Old 10-07-2010, 04:25 PM   #7
blacks
@33OH
well i tough i was the only one thank god but it's getting to me now because it gives the car a bad scent
Old 10-07-2010, 04:36 PM   #8
33OH
Drives: '08 Yaris
Yeah mine's real musty and gross. It's been doing it for at least a year or two. I took it to a body shop and they couldn't figure it out.
Old 10-07-2010, 04:56 PM   #9
blacks
And did you go to the dealer ?
Old 10-07-2010, 05:00 PM   #10
33OH
Drives: '08 Yaris
Yes but they blamed it on the body shop because my car was just repaired from a wreck when I noticed it. So they both blame each other and I drive a smelly swimming pool. :)
Old 10-07-2010, 05:04 PM   #11
blacks
so in other words no of them couldn't find the problem so they blamed it on each other
Old 10-07-2010, 05:51 PM   #12
sex
sex's Avatar
Drives: 09 5DR
How about spraying the car with a garden hose? You should be able to see where the water comes from
Old 10-08-2010, 02:22 AM   #13
derickveliz2
Exclamation
That's a good idea, also check under the carpet!
but who knows, where the water is coming from? what kind of accident did your car had? did the water started after the repair?
Old 10-08-2010, 08:15 AM   #14
33OH
Drives: '08 Yaris
It seemed to have started after the repair in my case. I will have to pull the carpet and check, thanks derick.
Old 10-08-2010, 01:06 PM   #15
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
Had that problem, some of the rubber plugs came off do to constant srapping the bottom of the car (trying to get a F**** parking at the university ) and i did some boddy damage. The dealer removed ALL the interior, they hire a guy to repair it.
I Drive a 129whp Yaris ;)
Old 10-08-2010, 01:06 PM   #16
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Maybe it's coming down from the door sills? Check that the seals are tight
Old 10-08-2010, 01:21 PM   #17
derickveliz2
Makes a lot of sense, water will never go up, it looks for the shortest distance to the ground.
D.
Old 10-12-2010, 08:21 AM   #18
blacks
Hi
It's me again this morning i woke up again and i saw it had a little drizzle tru out the night so my roof and a little water on it so when i went in i check the floor and it was a little moist not wet because it didn't really rain so my guest is the water is coming tru the roof does anybody have a idea of way on the roof it can be coming tru because i tried wetting it down n i didn't find where it was coming from ?
carpet wet passenger side dadmansfield DIY / Maintenance / Service 28 10-04-2022 05:51 PM
205-65-15 wet traction tires zachryboles Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 06-12-2010 02:07 AM
Pinging belt when wet or cold steveh74 Europe (continental) 0 08-22-2009 05:50 AM
Wet float bearings rkvin21 Forced Induction Forum 2 07-06-2009 02:09 PM
Wet Okole RS/S seat covers!! w/pics! PaidTimeOff Cosmetic Modifications (Exterior/Interior) 2 12-04-2008 06:53 PM
