#1 |
![]() Drives: 2008 yaris Join Date: Oct 2010
does defrost mode affect mileage?
i have noticed that the car runs significantly cooler when it is in the defrost/defog mode rather than the other settings. ( i usually don't even need to turn on the ac even on really warm days).
i just thought that the may be the possibility of the car automatically running the compressor part of the time or something like that. if this is the case i imagine i should stop leaving it in the defrost/defog mode to save some mpgs. |
In that mode the compressor is automatically on (unless you do the DIY to unlink that mode from hitting the switch for AC), so you definitely burn more fuel when the knob is turned that way.
#3 |
"LibertyRides!"
Drives: 2010 Yaris 3Dr LB | 2020 Stang Join Date: Mar 2010
^ Yeppers!
~ Mark ~ 2010 Yaris 3-Dr Liftback, 5-Speed Manual, P185/60R 15, Bayou Blue Pearl I Love my YARIS Most miles Tank: 538 tank/10.148 gal = 53.015 MPG / Most MPG: 54.95 MPG (ethanol) 425 tank/7.73 gal "The evils of government are directly proportional to the tolerance of the people." -- Frank Kent |
#4 |
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
To avoid the MPG hit but still enjoy some defrosting, simply keep the upper heater vents on and open one front window a bit. A sort of evaporation/sublimation occurs which clears off the windshield.
I have found that it takes a hand or two of opening to clear it but then just a few inches to maintain it.
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
#5 |
Crazy Oil Sniffer
Drives: MM 09 Yaris 5 Dr LB "Click" Join Date: May 2009
Thanks for the tip Brian!
#6 |
I've noticed on my Echo that selecting the foot or lower vents only still sends air up to the windshield, so I never turn it to full defrost unless it's really humid out and the windows won't dry up.
Anyone notice this on the Yaris? I know this little cheat doesn't work on my parent's Matrix. |
#7 | |
![]() ![]() ![]() ![]() ![]() Drives: no-longer-boosted '10 Yaris Join Date: Nov 2009
#8 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
#9 |
i tried mine and some air does go to the window but not alot...... i will try it next time i need the defogger and see if its an acceptable amount of air flow to defog/frost the window
#10 |
yeah it isn't a tonne of air, but I've found that using the A/C to defog the windows, you have to keep using it or the moisture taken out by the A/C core gets sent back into the car the minute you turn it off.
#11 |
Unless you leave it in fresh air mode.
#12 |
#13 |
Oh, I never have to move mine off of Fresh air + Foot even in the off position. It automatically defogs the windows for me. If I change it to re-circulated air, that's when the windows fog up.
Then again I do have a leaky car (water comes up through the floor), so maybe my constant fighting of fog is different than what we're talking about. |
#14 |
![]() ![]() ![]() ![]() Drives: Copper Orange Mica Yaris Join Date: Feb 2006
I just tried the what so called " foot mode" and it works!! It does however send limited amount of air to windshield to clear up the fog, Is it best to to go for coldest air rather than hot air to clear up the fog on windshield faster?
Will the "foot mode" activate the air conditioning?
![]() My Copper Orange Mica Yaris with 9.3lb Kosei K1 TS http://www.yarisworld.com/forums/showthread.php?t=10951 http://www.yarisworld.com/forums/showthread.php?t=13882 http://www.yarisworld.com/forums/sho...180#post472180 |
#15 |
No foot mode does not. Only the two settings with defrost and defrost/foot. And go with warm air to defog the window. Once the windshield is warm, moisture won't condense on it anymore. Plus, warming cold air lowers the humidity level of the air itself, as cold air can not hold as much moisture as warm air can.
#16 | |
| -Mileage Thread- -Log your mileage, year, model, color, any problems here... | Kal-El | DIY / Maintenance / Service | 317 | 07-20-2016 10:07 AM |
| Does Gas Mileage Increase After 1st Oil Change? | ChilliwackGuy | Fuel Economy Forum | 10 | 08-04-2010 02:13 PM |
| 2009 Yaris Mileage | wornways | Fuel Economy Forum | 3 | 07-29-2009 11:42 AM |
| Easy Defrost A/c running fix | billk | General Yaris / Vitz Discussion | 14 | 01-16-2009 08:53 PM |
| Performance mods that won't affect/will hardly affect gas mileage?? | Mr.Yaris | Performance Modifications | 15 | 07-30-2007 12:32 AM |
