Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Marketplace > Willing to Buy by private party
Old 10-08-2010, 11:42 PM   #1
sleey0
Drives: 2008 Yaris LB
WTB: Injectors to run 14psi MAX
let me know if you find any that will run 1 bar max and you can get a "finders fee" lol
Been searching fleabay and all I come up with is 1ZZ injectos.
And no I don't want to spend $400 on injectors. There are plenty of Bosch and Deutchwerks (sp?) but insane pricing.
Thinking of going to the junkyard soon....
"And that goes for any of you, never get put down from someone who gets jealous of you; build it and prove them wrong. There will always be haters and naysayers but those are also the ones who's cars are worth less than my seats."
xbgod - 9/23/2010
sleey0 is offline
Old 10-29-2010, 03:54 PM   #2
Injectors normally run at 50 or so PSI. I've never heard of any running at 14.7.
Bluevitz-rs is offline
Old 10-29-2010, 04:23 PM   #3
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Believe he means injectors that would best suit running a turbo at 14psi MAX boost.
fnkngrv is offline
Old 10-29-2010, 10:02 PM   #4
yariseggvvti
Drives: Yaris Hatchieback
You gotta be done a lot of work to running a pound of boost in to your engine. Keep it in stock and spend those money for suspension.
yariseggvvti is offline
Old 10-30-2010, 02:43 PM   #5
^ If he wants to build the motor and run some boost, why not?
cali yaris is offline
Old 10-30-2010, 07:08 PM   #6
cdydjded
Drives: Yaris LB Turbo
Injectors are rated for HP not boost pressure. Any injector will work for 14lbs of boost. The issue is does the injector supply enough fuel for the 14lbs of boost. So what you need to be asking yourself is:
How much HP to I plan to make?
What size injector do I need for xxx HP?
cdydjded is offline
1zz injectors suit the S/C just fine LtNoogie Forced Induction Forum 51 04-30-2016 10:11 AM
IS IT SAFE TO RUN TURBO ON STOCK INJECTORS ? Faraz_Shaikh Forced Induction Forum 9 10-19-2010 04:01 PM
