Old 10-11-2010, 02:45 PM   #1
Faraz_Shaikh
Drives: Toyota Vitz
HOW TO INSTALL AIR INTAKE IN YARIS ?
Dear Experts
I;ve 1.0 yaris, the problem im facing is that when i remove the VVTI box from the throttle body to install air intake with pipe so the car does not starts due to maf sensor problem so kindly suggest me what should i do? presently im running intake on that vvti box.
IF I GET EXACTLY PIPE OF THROTTLE BODY SIZE AND I MAKE SOME PLACE FOR THE MAF SENSOR ON THAT PIPE SO WILL IT WORK?
I'M IN NEED OF URGENT HELP.
THANKs
Faraz_Shaikh is offline   Reply With Quote
Old 10-11-2010, 03:15 PM   #2
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
Sounds like that's the problem gonna need smaller pipe
Originally Posted by sw07gt
Old 10-11-2010, 03:32 PM   #3
Faraz_Shaikh
Drives: Toyota Vitz
the point is how to start the car ? because the car fails to start when the vvti box is not there
Old 10-11-2010, 03:55 PM   #4
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
did you tranfer maf sensor to new intake? maybe you should post pics of your problem
pic of your intake and what you putting on would help alot
OTA'sTOY is offline   Reply With Quote
Old 10-11-2010, 04:00 PM   #5
Faraz_Shaikh
Drives: Toyota Vitz
i'm not having the pics right now but ill do this setup( mentioned below)
http://www.pakwheels.com/forums/d-i-...71700-wrd-vitz
now question is shall i transfer maf sensor to intake pipe? will it work?
Old 10-11-2010, 05:27 PM   #6
OTA'sTOY
OTA'sTOY's Avatar
Drives: '10 5dr
yes if the MAF sensor is on the stock intake pipe you must transfer it to what you are trying to put on aftermarket hose. the link you have attached page 3 shows where he ziptied the sensor (red circled post#41 close to throttle body) to the hose does'nt look so garans but can't see how he did it so GL
Old 10-11-2010, 07:33 PM   #7
big lo
big lo's Avatar
Drives: 2007 VIOS
I would like to see some pics when the job is done please
Old 10-12-2010, 07:05 AM   #8
Faraz_Shaikh
Drives: Toyota Vitz
alright
The great intake debate! fmicle General Yaris / Vitz Discussion 74 10-06-2009 11:37 PM
Install a Yaris deck into a Matrix... bad idea?? Help needed!! SimmZ In Car Entertainment + Electronics (audio / video / alarm) 4 12-17-2006 01:01 AM
