Old 10-11-2010, 08:28 PM   #1
Bishop
Drives: 2007 Yaris
Preliminary questions about engine conversion
I have been considering converting my car to a hydrogen system, not not some hokey ebay bullshit. but the problem is, they do not recommend using the system on an engine with a higher then 9.5 to 1 compression ratio. I have a 2007 Yaris, its all stock. So the engine has a 10.5 to 1 compression ratio. The issue is because hydrogen burns much faster then gas, which can cause predetonation at higher compression ratios. I am hoping that because the engine is aluminum instead of cast iron it may not have the issue as much? If not, any ideas as to what would be a good engine to swap it with that has a 9.5 to 1 ratio (or lower)?
Bishop is offline   Reply With Quote
Old 10-11-2010, 08:34 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
wow...sounds like a hell of a project. I have no useful information for you, but I wanted to truly wish you best of luck...very cool.
Old 10-11-2010, 09:21 PM   #3
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
swapping the engine sounds like it would cost a ton. You could also look at getting lower compression internals. Rods and pistons I believe.
Colin Chapman disciple
Old 10-12-2010, 02:59 PM   #4
markitect
You might be able to get a head spacer made to drop it enough, but I haven't seen anyone with one on a yaris, some of the boosted people might use one.
markitect is offline   Reply With Quote
Old 10-12-2010, 03:47 PM   #5
Astroman
Modded Moderator
Astroman's Avatar
Yeah the boosted guys would know more. Sounds like a neat project!
Old 10-12-2010, 04:41 PM   #6
Swap CP 9.5:1 pistons into it.
you won't need aftermarket rods unless you're going to make MORE than stock power.
noob here.. need help on questions about turbo and engine life 10Kyaris Forced Induction Forum 43 10-06-2010 09:26 AM
