Old 10-13-2010, 08:08 PM   #1
bankrobber
Drives: 2007 Yaris Hatchback
A/C draining onto floor
Today it just started dripping water when making Left turns. I admit I have never pulled the cabin filter out. Wasn't even sure if it had one. Well I pulled glove box out and I see it did come with one. Where is the hose located that drains the water? I am guessing the passenger side close to firewall. Is that right? I have to put on stands to get under it so any advice on best way to clean out the line. Coat hanger?
I have a 2007 HB with 98,000 miles
Old 10-13-2010, 09:03 PM   #2
You can get at it from the top side. Pull back the upper left corner of the passenger carpet and you'll see the hose. Just have a good sized pan to drain it into.
Old 10-14-2010, 10:57 AM   #3
bankrobber
I was wrong id doesn't have a cabin air filter. I pulled line off and pushed the only thing I could find which was some electrical wire. I did start to have a slow stream of water. I had to go to work so I guess it might have drained out on the way. I turned on the A/C today in the driveway and didn't see any water dripping onto ground. Hopefully that fixed it. Thanks for advice
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
The Official *MAD DOG* jokes thread v2 *MAD DOG* Off-topic / Other Cars / Everything else Discussions 771 05-22-2013 11:25 AM
Hole in floor mat from aggresive driving! YarisSedan Cosmetic Modifications (Exterior/Interior) 6 10-01-2009 02:36 AM
DIY Floor mats chadmw06 DIY / Maintenance / Service 5 08-30-2006 12:47 PM
