Old 10-14-2010, 07:31 PM   #1
Uber_Otter
Uber_Otter's Avatar
Drives: Black XA not yaris but close
Liquid and bead wheel balancing
Has anyone tried dyna beads, equal, or liquid wheel balancers like Delta?
Dyna beads= tiny ceramic beads
Equal= coated sand
Delta= liquid, like anti-freeze
You put one of these inside the tire 2-3 oz and once at speed they dynamically move to the oppisite side of the heavy side of your tire. Your tire is balanced for the life of the tire. I have a scion XA so no TPMS to worry about messing up.
I like the idea of the liquid because it helps with cooling.
anyone tried this stuff?
Uber_Otter is offline   Reply With Quote
Old 10-14-2010, 07:47 PM   #2
Black Yaris
der Zeck
Black Yaris's Avatar
They never hold a balance, and usually vibrate worse than no weight at all
any reason you were looking into this?
Long as you match mount your tires, and balance on a quality balancer you are fine
Old 10-14-2010, 07:50 PM   #3
RedRide
RedRide's Avatar
Agreed!
Old 10-14-2010, 08:33 PM   #4
firebob
Drives: 09 yaris
There have been a few different types of ceramic beads that have been used in semis over the years and tons of people swear by them for the larger tires. In the last few years the ceramic beads have made there way into motor cycle wheels and cars. The key issue with adding the beads is using the right amount of beads for the tire size. If the right amount is not added then there will be issues.
All liquids change viscosity with temp. I don’t know much about using an antifreeze type liquid in tires except on farms where they use it to change the weight of the tractor.
The last few sets of tires I have bought I have had ceramic balancing beads.
09, 3 door lift back, auto. I live on the road with my wife. We travel as needed for our work and drive up to 4,500 miles in a bad week.
firebob is offline   Reply With Quote
Old 10-14-2010, 09:51 PM   #5
jonismyname
Drives: 08 liftback 5spd
i use dyna beads in my motorcycle tires. if i could mount car tires at home, i would use dyna beads in those too. balance machines are questionable in some shops, so if you don't know what to look for or what to expect your results may vary. and balancers won't account for plugs and missing weights down the road. yari' have much easier lives than my bike and truck, but if it works reliably then it works...
jonismyname is offline   Reply With Quote
Old 10-14-2010, 10:12 PM   #6
severous01
fluid dynamics says it's going to move the furthest away from center...no matter the balance of the wheel. so, if the out of balance section is vibrating and the wheel is moving in an eliptical manner, the liquid or free moving parts will migrate to the furthest point....hence making balance worse.
i saw a bmw with these in there...they said they'd had the balance done about a week before and they couldnt take it any more. so, we stuck weights on it and perfect balance. happy customer.
i wont use the liquids or bb's in mine. too much to worry about.
Old 10-15-2010, 11:59 AM   #7
Uber_Otter
Uber_Otter's Avatar
I bought a tire changer tire changer and a bubble balancer from harbor freight. So now I can do my tire work myself, this lets me buy used tires really cheap. A set of 4 with say 70% tread life is not worth paying to have the mount and balance done by a shop. But for me to do it, its free. The tire changer works great as long as you use enough tire lube and bolt it down to the concrete. A bubble balancer is as good as you make it. I drive a lot, and I'm fairly hard on tires, about 30,000 a year. I'm going to try this stuff because I can now and its not a big deal to swap back to weights. Hopefully my wheels wont explode :)
Old 10-15-2010, 01:01 PM   #8
Uber_Otter
Uber_Otter's Avatar
Yes that's true, it only works when the tires on the road or spun on non-fixed axle. When the heavy spot is at the top the wheel hops up enough to pull whatever media your using to the opposite side. This continues until the tie balances itself out.
If you spin it on a fixed axle like a spin balacer it will do exactly what you are saying.
http://www.innovativebalancing.com/HowItWorks.htm
