Old 10-17-2010, 09:37 AM   #1
evo165
evo165's Avatar
Drives: peArL yAvItZ!!
Send a message via MSN to evo165
AEM/Injen CAI with Auto trans, pls comments...
Hi all bros, anyone with the above set up please kindly comments if the set up affect the performance of the acceleration & response?
Currently i am on stock air box with K&N drop in with custom CAI piping from foglamp area.
I am afraid with the Aem or Injen CAI system will hurt the acceleration response due to my auto tranny. Don't wish to lose out for my low-end...
P.S. I did search for the above, but still no luck finding the answer i need.
1NZ-FE Yaris with JDM RS front & rear bumper | JDM Vitz RS taillamp | JDM Vitz window visors | JDM Vitz Netz logos | JDM leather steering wheel & shift knob | 4k HID | K&N panel filter | Fujitsubo Wagolis exhaust | NST 10% crank pully | KYB Excel-G shocks | NF210 Springs | Cusco 4 points lower arm bar & Type OS top struct bar | RZCrew sub-frame collars | Ultra Racing 19mm rear sway bar & rear lower & center braces | PG Rear 13mm hub spacers | Exzess 2-pot calipers with 282mm rotors | Runstop Rear Disc | SSR Semi-Forge Type F 15" rims | Michelin Pilot Sport 3 195/55/15 tyres
evo165 is offline   Reply With Quote
Old 10-17-2010, 11:47 AM   #2
nightstalker
Drives: 08 yaris lb
I have the injen sp cai and noticed the difference. I believe u feel the gain in the low and mid range. Noth much but not enough to say ur driving porsche or anything of that matter
nightstalker is offline   Reply With Quote
Old 10-18-2010, 01:14 AM   #3
evo165
evo165's Avatar
I found the infomation on my local Toyota "Vios" forum. Alot comments that the using a "open pod" filter set-up gonna hurt the low end acceleration. I am not sure how much does it hurt therefore i am asking for more information here.
From my understand, driver who drive stick gear can control the half clutch motion with the engine therefore the low-end doesn't hurt much. Due to many engine mod lovers, open pod filter usually give & open up the high end...
Pls don't frame me, this is what i heard from others.
Old 10-19-2010, 02:31 PM   #4
TrashCan Monster
Drives: an egg
you should be fine.
TrashCan Monster is offline   Reply With Quote
Old 10-19-2010, 05:03 PM   #5
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Most dynos of cai's i have seen usually have a very slight loss of hp at the very low end of the range. Usually that translates into a 1 or 2 hp loss at the bottom of the rev range that you simply will not be able to feel.
If you are worried about any low end losses at all, just do the research on the product before you buy it. Maybe you can find a product that is focused on more power for the lower end, but that product won't be able to do as well at the top end.
Most of that stuff is designed to open up the top end of the rev range, that is where real power is made on most cars.
Colin Chapman disciple
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 10:57 PM
