Old 10-18-2010, 08:55 PM   #1
Qmobile
that's right I went there
Qmobile's Avatar
Drives: '08 Blazin' Blue,'10 Dark Red
back seat removal difference?
For all you who have taken the backseat out of the LB is the a real noticeable difference? all I've seen is to take it out you have to take out the rear floor trim is there a way to do it WITHOUT takin the all out? or would'nt look/work right?
Mods: 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals.
suggestions always welcome
Qmobile is offline   Reply With Quote
Old 10-18-2010, 08:59 PM   #2
Slick
Slick's Avatar
Drives: '09 3-Dr
I removed just the seat in my 09 LB and left the rear stuff in place. The rear deck thing is firm in its place and doesn't require the rear set to be still. Its just a few bolts and a clip here and there for the bottom cushion and out she comes. I also left the black frame thing in place, but it can be removed as well. Hope this helps :)
Old 10-19-2010, 05:31 AM   #3
Qmobile
Qmobile's Avatar
it helps a lil bit but just to make sure we're talk about the same piece staying on. I'm talking about the thing that goes over the spare tire. have you noticed any difference?
Old 10-19-2010, 06:20 AM   #4
Freedan
Drives: 2010 Yaris Bayou Blue 3DR Lift
I'm not sure if you have a 60/40 seat, but I'm planning on taking the 60 seat out. It would look pretty sweet to just have the 40 seat back there.
My plan is to have the three remaining seat (driver, passenger, rear 40) replace with racing seats. I won't be installing racing seats until my little Yaris get either a Turbo or Supercharger installed.
Racing seats in a 100 hp car that gets beaten by soccer moms in their suv just wouldn't seem right.
Freedan is offline   Reply With Quote
Old 10-19-2010, 07:27 AM   #5
justjesus
justjesus's Avatar
Drives: 2008 Liftback
LT Noogie has the rear 40 in his car. Kinda cool. The rest of it is gutted (stripped) out.
Old 10-19-2010, 07:56 AM   #6
you can put the spare wheel cover back on afterward, if I recall it is wedged into place by the two plastic bins on each side of the spare. Mind you, that's with the full bench seat, no idea about the 60/40
Old 10-19-2010, 08:55 AM   #7
Klink10
Klink10's Avatar
I removed my 60/40 awhile back leaving the part that covers the spare (didn't need to remove to take seat out). Even removed the spare but thought better of it. I have the tray that sits on top of the spare cover and fab'd up some brackets to hold it in place or to keep it from sliding forward. Does the car go faster? Dunno, but it's lighter and I don't carry anybody anyway.
Old 10-19-2010, 09:46 AM   #8
33OH
Drives: '08 Yaris
I noticed a lot more road noise and awkward, slanted cargo space. So mine are back in now. :)
Old 10-19-2010, 09:50 AM   #9
Qmobile
Qmobile's Avatar
yeah I have the 60/40 in the back. So I can take it out without takin the whole spare tire well assembly out then? And actually Klink that's why I want to do it, it's usually just me in the car. I know I've seen something awhile back on what all I need but to save a lil time what all would I need to do this?
Old 10-19-2010, 11:28 AM   #10
33OH
Drives: '08 Yaris
A metric socket set and 30 minutes.
Old 10-19-2010, 11:32 AM   #11
Klink10
Klink10's Avatar
Q......metric socket set and the star type sockets. If I remember right I picked up those stars at Northern Tool. They come like 6-7 a set in a plastic holder. Just use your ratchet with them. Depending on how clean underneath your car is you might find the ends that protrude thru the floor may be rusted/dirty....get some PB blaster or WD 40 (NAPA) squirt/soak and slowly remove. Gonna need a fair amount of oooommmmph but do it slow so not to snap or strip. I don't think I forgot anything....ifin I did holler back.
Old 10-19-2010, 12:06 PM   #12
33OH
Drives: '08 Yaris
Hm.. I don't have the 60/40 but I didn't need any "star sockets." Just a 12mm and a 10mm if I remember correctly. I just did mine a few weeks back to pick up a loveseat in it.
Old 10-19-2010, 12:35 PM   #13
Klink10
Klink10's Avatar
On mine I did (but now that I think about it those might have been where the seat belts were affixed to the floor). Pic shows bracket(s) I fabbed up to hold board cushioned with BMW floor mats from car I detailed. Until something more permanent. While I'm at it if you'll notice between the seats in the console there is a change holder from a Scion TC that holds my garage/shop door opener perfectly. It fits there real nice. Just in case anybody asks.
Old 10-19-2010, 12:36 PM   #14
33OH
Drives: '08 Yaris
Ahh gotcha - I left my seatbelts in. :)
Old 10-19-2010, 05:17 PM   #15
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
I took it all out. The rear of the car sits higher, and i think the car handles a little better.
I hate that uneven rear floor. I wish they made it flat, would have been so much better.
Colin Chapman disciple
Old 10-19-2010, 08:06 PM   #16
Klink10
Klink10's Avatar
Me too. Could build something to even it all out and somewhere on the forum someone did. But I think it would defeat the whole purpose of weight savings.
Old 10-19-2010, 10:57 PM   #17
Qmobile
Qmobile's Avatar
I mite take a look at the bolts. right now I run with 'em folded flat, it's ok but I'm still kinda up in the air. how uneven is it w/o the seats? where is the uneven part where the seat used to be?
Old 10-19-2010, 11:09 PM   #18
Slick
Slick's Avatar
Drives: '09 3-Dr
http://www.yarisworld.com/forums/showthread.php?t=306
Everything you need to know is here :D
Later in the same thread the OP posted the changes that he did to the rear.
http://www.yarisworld.com/forums/showthread.php?t=984
DIY - Sparco Race Seat Install Idjiit DIY / Maintenance / Service 16 08-14-2017 09:15 PM
Back Seat Removal... Idjiit DIY / Maintenance / Service 87 02-08-2015 12:07 PM
Back door panel removal ('00 Vitz) HELP ! Demon DIY / Maintenance / Service 2 09-27-2010 08:42 PM
Sedan rear seat removal guzziknight DIY / Maintenance / Service 4 06-11-2009 05:29 PM
