Old 10-19-2010, 05:55 PM   #1
Yar Is Word
Drives: Yaris 5 door liftback
The Gas Sway?
Hello!
How will adding a rear sway bar affect gas mileage?
Thank you.
Old 10-19-2010, 06:31 PM   #2
It won't, unless you count the addition of 13 pounds weight.
Old 10-19-2010, 06:49 PM   #3
chrisj
Hooch Brewer-Shine Sipper
chrisj's Avatar
Drives: 2009 5-dr LB
^ LOL!
chrisj is offline   Reply With Quote
Old 10-19-2010, 07:06 PM   #4
RedRide
RedRide's Avatar
I just might decrease gas milage a bit it you find yourself driving more agressively at times due to the better (faster) cornering the swaybar enables.
Old 10-19-2010, 07:22 PM   #5
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
is that the 19mm or the 23mm?
Old 10-19-2010, 07:44 PM   #6
sickpuppy1
Drives: 2010 Yaris Sedan
Yeah I would think the only effect would be tire wear cause I now love throwing my car into corners,lol. But I also love how much more stable it is in cross winds.....big difference!
Old 10-19-2010, 11:35 PM   #7
severous01
you can probably assume 1mpg per 100lb...roughly. and this all depends on weight to begin with, power, and gearing...but you can assume 1mpg/100lb
so, take your .13mpg and decide to coast instead of hitting the gas and you'll get it back...or, you can decide to lose 13lbs and make it up.
Old 10-20-2010, 12:12 AM   #8
chrisj
chrisj's Avatar
^ Well, when I load mine up with my crew, my MPG should drop to about 10. :)
Old 10-20-2010, 01:04 AM   #9
Slick
Slick's Avatar
Drives: '09 3-Dr
I dont know if that is 100% accurate because I'm a big ol fatty, bout 375 and I still get an average of 36mpg. I've even get close to 40 before during long trips.
Winter Gas Causing Drop in MPG? MadMax Fuel Economy Forum 66 03-21-2010 04:46 PM
Rear Sway LINK BRACE djct_watt Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 12-16-2009 03:29 AM
Economics of Price Gouging and Gas shortages GeneW General Yaris / Vitz Discussion 1 10-31-2008 04:20 PM
Free gas for any vehicle. ketel0ne General Yaris / Vitz Discussion 4 09-19-2006 08:07 AM
