Old 10-24-2010, 02:57 PM   #1
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
Wiring Problem; Help is greatly appreciated
So I was going about removing the stock radio to replace it with a pioneer head unit. we had spliced the wires and it was getting dark.. my friend rubber banded the wires together for neatness... so next day i turn on the car in the morning and i hear an electrical spark and it sounded like it came from the wires so i saw the situation and unbanded them. I didn't know at this point if i had messed anything up or just clicked em. So we go install my head unit and it doesn't seem to work. Here we are thinking maybe we put the wrong wires together and after double checking, I soon realize my dome/map lights don't work anymore. So now I have my dome/map lights and my radio not getting power whatsoever. Everything else works fine though like my trunk light etc. I am stumped at this point; could my complete wiring have been fried when the wires all touched?
Any solutions/insight anything at all really would be great from some of our electrical techs here. Thank you for reading.
Its a Chao!!!
Old 10-24-2010, 03:07 PM   #2
First off, it sounds like you popped your DOME fuse, which is in the under dash fuse panel. It supplies power to the dome light, as well as unswitched power to the radio. Most radios won't power up without the backup power being supplied, as well as the ACC switched power.
Old 10-25-2010, 12:27 AM   #3
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
I wouldn't have the stereo hooked up when you replace the fuse, I'd do another visual check and make sure no wires are touching, or stripped, the metal back there is pretty sharp, so make sure nothing is grounded. After that i'd turn the key and again do a visual inspection of the wires, make sure nothing is smoking and that the fuse doesn't pop again, after this then i'd hook up the Stereo and hopefully the problem is solved.
Old 10-25-2010, 05:34 AM   #4
Tamago
Tamago's Avatar
Drives: UZJ100
when you say splice Carlos.... does that mean you didn't buy a harness? i recommend picking one up, they're cheap (wal mart is the cheapest) and will virtually prevent this problem from occurring again. a little solder and shrink tube will go a long way too.
Old 10-27-2010, 10:04 PM   #5
TheRealEnth
Beast
Well its a little too late; yes we spliced before realizing i could get the harness >.< I already tried switching the fuses; but ill buy new ones and see
Its a Chao!!!
Old 10-28-2010, 06:53 PM   #6
Tamago
Tamago's Avatar
Drives: UZJ100
solder, shrink tube, fix that stock wiring!!!
did you lose my number? you could have called me man!
Installing Trailer Light Harness vandallen DIY / Maintenance / Service 7 06-10-2024 10:06 AM
How did $69 Maintenance turn into $311 ??? Any opinions greatly appreciated. sherriebythesea DIY / Maintenance / Service 28 10-11-2010 10:54 PM
interior lighting problem tied with headlights 40oz DIY / Maintenance / Service 7 03-28-2010 07:52 PM
Launching @ 4Krpm problem .... need tips Parmas Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 12-30-2009 08:11 PM
Wiring Pictures MitchEvious In Car Entertainment + Electronics (audio / video / alarm) 2 12-28-2009 11:43 AM
