Old 10-28-2010, 07:31 PM   #1
SimTronik
Machinist
Drives: Yaris sedan 2010
Under dash Led light
Hi i'd like to install under dash LED lights. I'd also like to know if its complicated to install (please explain) and where is the best place to get some.
Thanks in advance.
SimTronik is offline   Reply With Quote
Old 10-28-2010, 07:45 PM   #2
jamal1984
The Beautification of Car
Drives: Toyota Yaris S
Thanks in advance.
you can buy the factory kit from Toyota, it's come with instruction, nice switch button, but only blue color, or you can buy leds from anywhere you like ebay, walmart, advance auto parts, pepboys, and you wire it in to the cigarette plug just + n - that it is, so it's will on when the car is on
Old 10-28-2010, 07:56 PM   #3
SimTronik
Machinist
i didnt know Toyota had a kit. Interesting! Is it expensive? Does anybody have the part number?
Old 10-28-2010, 09:29 PM   #4
jamal1984
It's over 100 I got from bay for like $ 36 missing parts " just a few connectors" but yeah I will not pay for over 100
Old 10-28-2010, 09:57 PM   #5
big lo
big lo's Avatar
Drives: 2007 VIOS
I think there's DIY around here somewhere
Old 10-28-2010, 11:08 PM   #6
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I did mine for less than 15 bucks if you take out the potentiometer that I installed so that I could make them as bright or dim as I wanted. I did the same as the others recommended and spliced them into the 12v circuit.
Old 10-29-2010, 06:36 AM   #7
SimTronik
Machinist
I'll try to find the DIY. Have any links where you bought yours? I'm not just so good in electrical things.
Old 10-29-2010, 09:21 AM   #8
fnkngrv
fnkngrv's Avatar
This is who I went through for mine:
http://stores.ebay.com/Formula-J87?_rdc=1
They sell different lengths of LED Strips and they are rubber coated so they are protected pretty well. You can cut them down to smaller sizes if you want. They are direct 12v compliant so no need for inverters. They have positive and negative wires, that's it so it is pretty simple really. As for a DIY I didn't do one myself because it is pretty straight forward however I do sympathize with your unsure feelings about electrical as I was the same way for a while with my car. As me to wire a house or classic car no problem, but for some reason as me to deal with our car's wiring and I was unsure. Be aware that if you installed a dimmer switch like I did it will most likely introduce feedback noise through your stereo. For starters I would recommend you go through this thread:
http://yarisworld.com/forums/showthr...ighlight=wires
Old 10-29-2010, 02:42 PM   #9
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
you mean like mine?
There are lights in the center cubbies as well
Check out my Build thread:
Old 11-03-2010, 03:32 PM   #10
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
I have some I wired in to the 12v door circuit so they fade in and out with the cabin lights. I also put in a switch so that I can turn them on or off as I please to bypass the door circuit.
Old 11-03-2010, 09:51 PM   #11
SimTronik
Machinist
Thats nice :)
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
Green LED Dome Light and Underdash LEDs Installed fnkngrv Cosmetic Modifications (Exterior/Interior) 11 08-20-2010 12:38 PM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
DIY for Low Cost Dim Light in the light LED tang DIY / Maintenance / Service 0 03-08-2009 10:58 PM
