Old 12-24-2006, 03:50 AM   #1
T0ny2oo4
Drives: Polar White Liftback
CAMBER KIT
for all those of you whos lowered your liftbacks with Tanabe DF or Teins. was there enough play in or stock cambers to align the wheels?
T0ny2oo4 is offline   Reply With Quote
Old 12-24-2006, 01:16 PM   #2
03Z33
03Z33's Avatar
Drives: TCR10
The only aligment change you can make from the factory is front toe. Plenty of adjustment there.
If you want to adjust front camber, you'll need to order the bolts from Toyota or from SPC. I got the smallest top bolt (12.4mm) from Toyota and that allowed me to get over -2 degree front camber. These will also allow you to go back to -0.5 degree front camber which is closer to factory spec.
For the rear you'll need to use shims to adjust toe and camber. You can use generic camber shims, or you can purchase rings that fit between the hub and the beam made by SPC part# 75800. These allow you to change camber and toe at the same time. I'm running -2 degree camber with close to 0 toe in the rear and my car is VERY low
03Z33 is offline   Reply With Quote
Old 12-24-2006, 09:19 PM   #3
T0ny2oo4
i guess that is a yes then that i need a camber kit
Old 12-24-2006, 10:29 PM   #4
DTM_Yaris
Turbo Yaris
DTM_Yaris's Avatar
Drives: 07 PW Yaris
Originally Posted by T0ny2oo4 View Post
i guess that is a yes then that i need a chamber kit
Don't take this the wrong way please.... but it is called CAMBER .... NOT chamber... Sorry
DTM_Yaris is offline   Reply With Quote
Old 01-05-2007, 11:42 AM   #5
T0ny2oo4
Camber Kit
Does anybody know if a kit exist for the 07 U.S Yaris Yet? IF SO, PLEASE LEAVE THE LINK.
Old 01-05-2007, 10:03 PM   #6
03Z33
03Z33's Avatar
Drives: TCR10
Front Camber bolts are available at your Toyota parts department for a couple of dollars each. You'll need to order them most likely.
Rear shim for toe and camber alignment is available from SPC, part #75800
http://www.spcperformance.com/PerfPa...rt_EZShim.html
Old 01-05-2007, 11:18 PM   #7
Black Yaris
der Zeck
Black Yaris's Avatar
you can go to any local Napa store as well to obtain Cam bolts
Old 01-06-2007, 01:14 PM   #8
T0ny2oo4
i called the dealer
he told me i would have to lower the car and bring it to an alignment shop to find out the right size bolt i needed. is this true?
also where can you purchase those shim kits alone. i only see full kits.
03Z33, thanks a mill, i bet this is gonna help hella ppl out.
Old 01-06-2007, 01:23 PM   #9
T0ny2oo4
one more thing... with those dealer bolts, would the alignment be adjustable? or would you be stuck with -1.2deg for the 12.4mm bolts.
Old 01-06-2007, 09:03 PM   #10
Tamago
Tamago's Avatar
Drives: UZJ100
it's adjustable because it's floppy.. so anywhere +/- of the slop in the strut
Old 01-06-2007, 11:09 PM   #11
03Z33
03Z33's Avatar
Drives: TCR10
Just like Tamago said, if you get the 12.4's which are the thinnest diameter, you will have the greatest range of adjustment. These should allow you to go all the way from -2 deg front (more then most will need) to 0 degree (less then you will want). So no need to get aligment first, just get the bolts and bring them when you're ready to get the aligment.
The adjustable cam bolts work just as well.
Toyota alignment bolts part numbers are:
90109-15001
90109-15002
90109-15003
90109-15004
Old 01-07-2007, 07:29 PM   #12
spkrman
Drives: 1
can a mod plz change the title of this thread, it hurts my eyes everytime i see it.... lmao... cmon guys go play gran tourismo and get edumacated like me :)
Old 01-19-2007, 01:03 AM   #13
T0ny2oo4
FINALLY GOT IT ALL DONE!!!
Turns out that i didn't need front camber bolts or rear shims with my Tein S-Tech drop. and i gained a lot of camber knowledge after going through it all.
Wait for some REAL camber bolt is my recommendation. true you can go smaller bolts but its going to be able to rock out of place when you hit bumps. GO TEIN if you want the closest to stock ride with the lowest drop.
Old 01-19-2007, 03:35 PM   #14
Mattattack
Drives: 2009 Yaris LB
Yo Tony. PLEASE post some pics of your Tein drop. The only pics I've seen are on the Tein website. It would be awesome to see another example. Thanks!!!
Mattattack is offline   Reply With Quote
Old 01-20-2007, 02:27 AM   #15
man...only if i could keep my warranty...i want those springs so bad.
Old 01-20-2007, 01:57 PM   #16
T0ny2oo4
Matt, if you ever saw the Tanabe Down Forms, they look just like those. but with teins you can be sure u have better quality springs and ride. but i will try my best to get those pictures when my wheel spacers come in.
Old 01-21-2007, 02:24 PM   #17
Mattattack
Thanks man. Pics would be sweet.
Old 01-21-2007, 03:49 PM   #18
T0ny2oo4
Yaris on TEIN S-Techs
hx wheels
Dash Kit - No Mods barryware In Car Entertainment + Electronics (audio / video / alarm) 8 09-14-2014 03:59 PM
For Sale: Lexus GS Parts - L-Tuned Body Kit, TRD Strut Tower bar, 18"StaggeredWheels. TRD_Yaris Items for Sale by private party 6 05-06-2010 06:43 PM
Is aftermarket HID kit legal (in NJ)? Jfoofoo Cosmetic Modifications (Exterior/Interior) 25 03-19-2009 02:05 PM
Gounding kit 07WYarisRS Items for Sale by private party 10 01-12-2007 10:43 PM
Toyota Echo or Scion Xa/Xb for aftermarket HU receiver kit? ceboyd In Car Entertainment + Electronics (audio / video / alarm) 7 12-08-2006 02:13 PM
