Old 11-07-2010, 04:42 PM   #1
magilla
Drives: yaris hatch back
HELP ME!!!
ok heres the problem.
i have a whooping pulsating sound coming from the front end of the car. it increases with the speed of the car.
i can not feel it in the steering wheel and the steering wheel does not pull either way.
i just had a center force clutch put in by a shop i knew would do it right.
i checked the torque on the cv axle nuts and they are fine and i checked for slop in the wheel baring but didnt find any
i swaped to my other rims and i still have the problem so its not a bent rim.
if any one has any ideas of what i could check it would be helpful
the car is a 07 toyota liftback 1.5 manual
magilla is offline   Reply With Quote
Old 11-08-2010, 01:12 PM   #2
magilla
any one any ideas????
Old 11-08-2010, 01:30 PM   #3
cdydjded
Drives: Yaris LB Turbo
If the sound started after the clutch install then the problem lies with the work done. Take it back to where you installed it.
cdydjded is offline   Reply With Quote
Old 11-08-2010, 01:45 PM   #4
if you're saying this started after the clutch install, then do what he says. ^
Old 11-08-2010, 03:32 PM   #5
magilla
ok that was the plan hopefuly they can figure it out
Old 11-29-2010, 05:02 PM   #6
yarisdude447
Drives: 2009 Yaris Hatchback
Yeah, definitely bring it back to where you had the work done. It sounds like maybe there's a loose bolt or nut somewhere, because it can't be something like suspension... which they shouldn't touch when doing a clutch install. Pretty safe to assume that if it was fine before the clutch install, and started doing this after the clutch install... you can probably bet that it's the clutch work that's at fault here.
yarisdude447 is offline   Reply With Quote
