11-11-2010, 07:23 PM | #1 |
Drives: 2008 toyota vios 1.5G A/T Join Date: Oct 2008
macpherson struts or brakes creaking?
hello.
i have a 2008 automatic sedan. my odometer reads about 38K kilometers. i have been feeling or hearing a creaking sound coming from the front of the car when braking. more so, if it's a sudden hard stop. i don't know if it's from the brakes or the macpherson struts. also up front, there's a slight knocking or clunking sound when the brakes are applied. are these problems connected? are they common? what could they be? thanks for any advice. |
11-12-2010, 12:59 AM | #2 |
Drives: no-longer-boosted '10 Yaris Join Date: Nov 2009
i think only a mod can move it. but ur noise, i hear a light clunk when brakes are applied the first time after being in reverse and going forward. my dads ML500 had the same issue from new (only it was alot louder) and he was told its the break pads moving front and back and its nothing serious.
i would check and make sure ur wheel studs are tight. also has any work been done to the front end of the car? i would start there. in very rare cases ive heard of ball joint making this sound.
If it has boobs or wheels sooner or later your gonna have problems with it |
Similar Threads | ||||
Strange creaking sound whenever applying brakes at stop position. | YarisSedan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 09-04-2015 04:51 PM |
Is this idle characteristic a problem? | Shinare | DIY / Maintenance / Service | 11 | 01-16-2012 07:02 PM |
macpherson struts or front disc brakes sounds? | auto pal | DIY / Maintenance / Service | 6 | 11-17-2010 06:50 AM |
general service of brakes | TriumphAnt | DIY / Maintenance / Service | 10 | 08-07-2010 02:20 PM |
Metal scratching from brakes | alt_k1ll3r | DIY / Maintenance / Service | 16 | 02-11-2010 12:04 AM |
