Old 11-15-2010, 03:55 AM   #1
Faraz_Shaikh
Drives: Toyota Vitz
TURBO INSTALLED ON 1SZFE
Finally the project has been completed and turbo has been installed in my ride after very hard work and experiments.
Engine is 1szfe
Turbo is Garrett T28
SSqv Bov
Return line made for installing FPR
225cc injectors
Top mount intercooler
Battery has been shifted to trunk
Hks Fcon Mini
Hks Afa
Boost i'm running is 8.4 Psi
The car has been tuned through wideband and the AFR was 10.5 to 11
Pics are attached below
Faraz_Shaikh is offline   Reply With Quote
Old 11-15-2010, 05:31 AM   #2
N3misiS
N3misiS's Avatar
Drives: Yaris T1 1KRFE
What is the power your are making?
F\A is on the Spot
“Do or do not... there is no try.”
N3misiS is offline   Reply With Quote
Old 11-15-2010, 07:22 AM   #3
xbgod
Drives: "Burning It Down GTX2860RS XB"
Thats a tiny intercooler. Won't be surprised if you dont get heat soaked. and with it's location I hope you have a hood to support it's off-side placement. Also looks like you got in a hurry towards the end of your project. not sure if all of this was well thought of before you placed things. Parts of it just look messy and not finalized. I think your intercooler size and placement will be an issue.
I'm not not knocking your efforts, I just think part of its not well thought through or finished looking.
XBG
xbgod is offline   Reply With Quote
Old 11-15-2010, 10:07 AM   #4
turboecho2005
turboecho2005's Avatar
Drives: 2005 Toyota Echo
I see nothing wrong with your intercooler placement. Remember this motor is only a 1L. The IC is an ok size. Having one too large and more piping will only result in turbo lag. You're current setup looks fine. Keep up the good work.
Project Slowtop - Twin Engine 4AGE Blacktop Vitz - Twin Turbo - 503hp
1987 Nissan Maxima - 40,000 original miles - Slammed
1991 Isuzu Impulse RS AWD Turbo - approx 250hp - Winter Beater
1989 Isuzu Imark RS - Mint Condition - 0 rust - 100% factory :) - Summer Cruiser - 100% restored
1986 VW Jetta Wolfsburg - 120,000km - Mint condition. TDI swap in progress
turboecho2005 is offline   Reply With Quote
Old 11-15-2010, 11:01 AM   #5
xbgod
placement of that intercooler will be fine...............as long as you can get air into it. And i'd rather have a little lag than heat soak.
XBG
Old 11-15-2010, 12:38 PM   #6
Faraz_Shaikh
Drives: Toyota Vitz
thanks
if you people have noticed so i have installed a powerful fan just below the intercooler which clears the heat thing issue.
As far as the performance is concerned so its going much better, we are having no dyno machines here but i think its making around 110 to 120 whp
Old 11-15-2010, 04:47 PM   #7
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
wow, that is pretty cool, i wonder how much lighter your model is, compared to ours.
Colin Chapman disciple
Old 11-15-2010, 05:03 PM   #8
Faraz_Shaikh
Drives: Toyota Vitz
@ why
dude no idea
Old 11-15-2010, 05:34 PM   #9
10.5 to 11 is a little rich!
Old 11-15-2010, 08:11 PM   #10
xbgod
I think your AFR is fine 10.5-11 really isn't that fat, better than running lean. If you were in 13's i'd say you were to rich but your number is very common. You could lean it out a little to 8.5-9 and still be safe but lets not detonate.
My one pet-peve clean up your pipping, Looks messy. Use more aluminum pipping and a weld bung for your BOV, V-Band if possible. Just looks like you ran out of time or patience.
XBG
Old 11-15-2010, 08:13 PM   #11
You're going backwards man, lower numbers are richer, and 10 is pig rich, not good for the motor.
Old 11-16-2010, 03:56 AM   #12
Faraz_Shaikh
Drives: Toyota Vitz
thanks for your comments and views
actually the thing is i'm first person who has installed turbo in yaris, few people have imported yaris which already have turbo kit in it , but i have been through many experiments thats why the work is lil messy, soon ill go for almunium piping so i could have a better look in engine bay.
I had to do different experiments to make this project sucessfull, secondly as far as i think the AFR is ok
another point which i'd like to share is that, car was not getting tuned by earlier , i used to disconnect o2 sensor so the car used to get rich, without boost like below 3000 it used to be very rich and as the turbo spools it used to be perfect, and if i used to run car with o2 sensor so it used to be lean all the time but like for 3 days i didnt disconnect the o2 sensor and used to do normal cruising but yesterday i made a try, i ran car with the o2 sensor the car was perfect, in all 3 gears it was perfectly awesome. i asked my tuner he said your car has been tuned automatically via o2 sensor.
Later i made another bunk next to o2 sensor for checking the afr, the afr was 10.5 to 11, when i disconnected the wideband sensor from that bunk the car again was in old situation, was in lean with o2 sensor so now i have again closed that extra bunk in manifold which i made for checking afr and now o2 sensor is connected.
So now my question is that will o2 sensor again tune my car automatically and control the fueling accordingly ?
Old 11-16-2010, 04:42 AM   #13
henry33
Drives: yaris1.33
hi man good work !!! really admire you !
henry33 is offline   Reply With Quote
Old 11-16-2010, 07:23 AM   #14
xbgod
Damn-it Cali your right "spent to much time in the sun" reverse what I said.
Brain-Fart
XBG
Old 11-16-2010, 08:07 AM   #15
XBG
X2
It's a ratio of Air:Fuel not Fuel:Air
Old 11-16-2010, 09:08 AM   #16
Faraz_Shaikh
Drives: Toyota Vitz
thx henry :)
Old 11-16-2010, 10:17 AM   #17
ok -- great project, best of luck with it, but I can't be helpful to anyone who maintains that 10.5 AFR isn't rich.
Old 11-16-2010, 10:46 AM   #18
Faraz_Shaikh
Drives: Toyota Vitz
so you think 10.5 is rich ?
Plan to install hks turbo kit on 1szfe Faraz_Shaikh Forced Induction Forum 5 10-19-2010 11:00 AM
Greddy Turbo installed Bluevitz-rs Forced Induction Forum 22 09-03-2010 10:51 AM
Turbo Project Yaris TS 1.8L CASTREX Yaris TS Talk 40 08-21-2009 10:24 AM
HKS turbo timer type 1 Tamago Performance Modifications 3 07-21-2009 11:59 AM
