Old 12-26-2006, 09:08 PM   #1
rwseattle
Rwseattle
rwseattle's Avatar
Drives: 2007 Toyota Yaris (BASE)
Question Wheels size?
I looking at several ENKEI wheels and found "tirerack website" two sizes for the 2007 yaris HB.
15 x 6.5 195/50/15 (car)
16 x 7 205/40/16 (car)
I've decided that I like the 15" or 16" v/s 17" or 18" primarily because I'm using my Yaris as a daily driver. I'm not completly sure about the 6.5 or 7 any comments? Would the 6.5 be better than the 7?
Thanks
Ron
rwseattle is offline   Reply With Quote
Old 12-26-2006, 09:18 PM   #2
Black Yaris
der Zeck
Black Yaris's Avatar
195/50r15 = wrong for Yaris, if you are going 15x6.5 I would go 205/55r15, relitivly low priced tire, and will run flush with a 6.5 inch wide wheel, as well as staying very close to the stock diameter tire... this same size tire would run fine on a 15x7 wheel as well
and if you want to run a 16 inch wheel I would go 215/45r16to get the closest overall diameter and fit nicely on a 7 inch wide wheel
Old 12-27-2006, 02:38 AM   #3
dngz
dngz's Avatar
Drives: black yaris sedan
id go with the 16x7, 205 or 215/45/16
dngz is offline   Reply With Quote
Old 12-27-2006, 03:03 AM   #4
graywolf_14
Drives: um not a yaris but hopefully
y
Y would the 205/50/15 b a bad choice? I have a eagle talon and was going to run eather the 205 or a 225/50/15.
graywolf_14 is offline   Reply With Quote
Old 12-27-2006, 03:11 AM   #5
Black Yaris
der Zeck
225-50-15 would be a good choice, it is very close to stock diameter, 205's would be way too small, throw the speedo off too much, and it just would not look right
both of those sized are pretty small for a Talon as well 215-60-15 would be more like what you need
Old 12-27-2006, 01:30 PM   #6
boris13
Drives: 2007 Yaris Liftback, 5-speed
Would 195-55-15 be OK (they're close to the stock/optional 185-60-15's in diameter and will fit on the 15 X 5.5 alloys)?
boris13 is offline   Reply With Quote
Old 12-27-2006, 09:40 PM   #7
graywolf_14
Well I like width and low sidewall. If I have a problem with wheel gap I will just lower it. I am more into how it will handle than how it looks. If I buy a yaris the looks will probley be one of the last things I will do.
Old 12-28-2006, 10:01 AM   #8
DTM_Yaris
Turbo Yaris
DTM_Yaris's Avatar
Drives: 07 PW Yaris
There are plenty of 15x7. That is what I recommend on this car.
Personally I run 225's and they fit to my liking. On a car that you drive daily I would stick with 205's or even 215's
DTM_Yaris is offline   Reply With Quote
Old 12-28-2006, 09:15 PM   #9
Black Yaris
der Zeck
suggested tire sizes to stay as close to stock as possible
185-60-15 stock
205-55-15 +1
225-50-15 +2
Old 01-10-2007, 07:39 AM   #10
Yaris TTE JWRC
Drives: 07 5spd red Yaris HB 1.5L 16V
I will go with 17s, yaris is a 1.5L line-4 supcompact car, 18s are for full size cars, anything beyond 18s are for trucks and SUVs
Yaris TTE JWRC is offline   Reply With Quote
When will the Yaris hit the showrooms at dealers? Petrolhead New YARIS Purchase Forum 181 11-28-2011 08:03 AM
Feedback on these wheels BulletProofAuto Wheels, Tires and Suspension Forum sponsored by The Tire Rack 21 06-04-2007 09:09 PM
Rim size difference???? marcus General Yaris / Vitz Discussion 2 11-03-2006 04:20 PM
Buddy Club Wheels BulletProofAuto Sponsors Classifieds Area 8 10-19-2006 07:55 PM
Size of steel 15" wheels? ketel0ne Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 10-09-2006 12:37 AM
